G
Guest
Guest
Hi all,
I have just put together a new system based on;
Athlon T-Bird 1.1Ghz
Abit KT7-Raid
Micron 128Mb with Parity cl2 * 2
Voodoo 5 5500
Sound Blaster live platinum
misc 10/100 ethernet card
2 * IBM 46 GB ATA100 disks (on raid channel with proper cable)
Philips 10x DVD on ide port 1.
NEC Floppy
The problem;
Went into bios and setup 1100 mhz CPU (there is no default option for this cpu in the bios)
Rebooted the PC and setup raid array. Rebooted to dos floppy to format etc.
Himem.sys gives memory errors 25% of the time, if it gets past himem then the system reboots.
If I leave the system alone it locks solid after about 2-5 mins in the bios screen cpu temp about 65-75 degrees celcius.
After some messing I selected the failsafe bios defaults and rebooted, now the system will only work if I press insert as I power on
Questions,
What bios settings should I be using? After consulting Toms review of the 1.1Ghz T-bird I set core voltage to 1.75 volts, but what should the I/o voltage be?
The cpu has 4 small pads of felt on it, after reading about cpu fans breaking the cpu I bent the fan clip so to reduce the pressure of the fan on the cpu. Could I have the fan to loose? how tight should it be?
Help!!!
Thanks in advance.
Jed Glover.
Abit KT7-Raid
Voodoo 5 5500
NEC Floppy
The problem;
Questions,
Help!!!
Thanks in advance.
Jed Glover.
