mn-500 base WEP encryption problem
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I recently decided to start using again my old mn-500
base station. Before that, I was using someone else's
base station, so mine just sat in the closet. I used to
have a 128 bit encryption. I plugged the base station and
a year later is still locked with that password which I
forgot. I reset it using the hidden button in the base,
but it wasnt help at all. I tried to reload the original
software, but since I have the SP2 upgrade its causing
too many incompatibilities.
1 answer Last reply
More about base encryption problem
  1. Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
    Make sure when you do the factory restore that the power light flashes
    Amber & Green. If it doesn't you have not done a factory reset. In
    that case you will need an object that can go farther into the hole.
    Please do not contact me directly or ask me to contact you directly for
    assistance.
    If your question is worth asking, it's worth posting.
    If it’s not worth posting you should have done a search on
    http://www.google.com/ http://www.google.com/grphp?hl=en&tab=wg&q= or
    http://news.google.com/froogle?hl=en&tab=nf&ned=us&q= before wasting our
    time.
Routers Encryption WEP Networking
