Com port resource problem
Kheldin
8
I just finished putting a new computer together and am quite pleased with its preformance save one thing. I have 3 com ports and onf of them always loads up saying there are not enough resources avail. For some reason Win2k will not see my modem unless it can see all 3 ports. So to be able to use my modem i have to for the com port open and then i'm free to use my modem. Was just wondering if any one has any ideas as to what i can do to fix it.
1ghz Thunderbird
KT7-RAID
640 megs ram
Elsa Gladiac 32 GTS
Soundblaster X-gamer
Firewire card
Aopen FM56-ITU/2 modem (PCI)
Thanks
Kheldin
doczenith1
144
Have you tried disabling the onboard com ports in bios? I think this might work, as I havn't had to mess with interal modems for quite some time...i have a cable modem (-:
