Solved
Help with system transfer!
  • Hard Drives
  • Windows 7
Last response: in Windows 7
January 3, 2013 3:32:25 AM
Im wondering what I should do to transfer my data to a new pc. My current one is running a 128gb SSD with a 500gb storage HDD. I'm building a new one with a similar configuration, but how to transfer my data? I was thinking to save a backup image onto an external drive, and load it with the raw files/programs from the HDD, do a fresh install of windows onto my new PC, then use the image restore utility to put my system as it was. I am already familiar with the fact that cloning utilities and the like are not good for the performance of my SSD.
Does this even work? If not then I would gladly appreciate a suggestion for my method. Thanks!
More about : system transfer
January 3, 2013 4:09:10 AM
m
l
Best solution
a b $ Windows 7
January 3, 2013 6:50:00 AM
If the hardware config is different I wouldn't use an image. Why not just backup the files themselves?
January 3, 2013 7:56:59 PM
Okay then that will work. I just didn't want the hassle of moving them all back in when I could just restore it. Thanks for the help :)
m
l
January 9, 2013 11:10:54 PM
Best answer selected by JackyDawg.
m
l
