T|T3: Bluetooth libraries gone?!? help!
Last response: in Cell Phones & Smartphones
Anonymous
January 25, 2005 8:35:47 PM
Archived from groups: comp.sys.palmtops.pilot (More info?)
Recently, my Palm T|T3 had a hard reset and I've had to restore from
backups, which were apparently rather poor. (despite having both
BackupBuddy and BackupBuddy VFS in action.)
It appears that my bluetooth libraries have vanished.
When I try to use BTtoggle, it tells me "This Palm
handheld doesn't appear to have a Bluetooth radio." and when I go into
the prefs, it says "Bluetooth Failure: Missing Bluetooth components.
Please re-install software." I can't seem to find updated BT drivers
on PalmOne.com to download and install. what should I do?
Any hints? help?
-alan
Alan Hoyle - alanh@unc.edu - http://www.alanhoyle.com/
"I don't want the world, I just want your half." -TMBG
Get Horizontal, Play Ultimate.
More about : bluetooth libraries
Anonymous
January 25, 2005 8:46:24 PM
In article <35nebjF4kp0t1U1@individual.net>, alanh@unc.edu says...
> Any hints? help?
> -alan
On your CD:\Essential_Software\PhoneLink\setup
Hope this helps.
Jim Anderson
( 8(|) To email me just pull my_finger
Anonymous
January 25, 2005 10:15:46 PM
>> When I try to use BTtoggle, it tells me "This Palm handheld doesn't
>> appear to have a Bluetooth radio." and when I go into the prefs, it
>> says "Bluetooth Failure: Missing Bluetooth components. Please
>> re-install software." I can't seem to find updated BT drivers on
>> Any hints? help?
Tried that. no change in any behavior. Doesn't even list Bluetooth
as an option in Phone Setup.
-alan
Anonymous
January 25, 2005 10:35:28 PM
>>> Any hints? help?
It turns out, my problem was exactly the opposite of what I thought it
was. Instead of having drivers that were too new, my backup restore
had drivers that were from 2001, I'm guessing left over from my T|T.
Deleting them from memory and reverting to the ROM versions made
everything work again. (This was my first hard reset since upgrading
last fall.)
-alan
Anonymous
January 26, 2005 12:13:27 AM
>> Any hints? help?
It sounds like a warm-reset (reset with up-button). This is not the
same like a softreset. After a warm-reset the handheld don't load any
system extension. Try a softreset or do another hard-reset. The
BT-driver should be installed from the rom.
Grüße
Thomas
