Tom's Hardware > Forum > CPU & Components > CPUs > Change power supply changed temp
Forum CPU & Components : CPUs - Change power supply changed temp
I have a Antec PP-303-x 300watt power supply. I felt that there maybe a problem with power supply. So call Antec and they sent me a new one. After changing the power supply. The CPU temp. changed. Before it would at idle 39C, it was the same everytime. I'm running a FOP38 cooler. With the new power supply it runs at idle 42C. The only change was the power supply. Does anyone have any input on why this happened.
Sponsored Links
Yeh, your voltages are different now, and your fan is running slower because of lower voltages. Antec seems to have that problem. I put up a post on it myself a while back.
Suicide is painless...........
Reply to Crashman
As posted, it has to do with the voltage. You might want to try using a hardware monitor (e.g. simply Asus Probe if you have an Asus board) to look it over yourself.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
did you bump your heatsink so it no longer makes good contact with the processor? or did you remove and reinstall your heatsink?
Reply to Anonymous
I love ASUS PC Probe.
I also love the fact that I don't need it.
But I run it anyway. :)
- Sanity is purely based on point-of-view.
Reply to slvr_phoenix
I don't think I did.
Reply to Anonymous
There are 743 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
