G
Guest
Guest
I need some networking help. The computers in my house are pretty spread out, and it's an older house so I can't use traditional cables. First of all, the server computer (cable modem) is on the second floor, and another computer is in the basement - these two computers are connected by a phoneline network. the computer in my room is on the same floor as the server, just across the hall (but the cord is about 25-50 ft long). Right now, I am also connected on that phoneline server. It's a 1mbs connection, which mean i SHOULD be able to pull at least 100 kilobytes/s, but things usually start downloading at 80k/s, then immediately move down to 30k/s, where they stay. The server computer can get up too 300+k/s downloads!
What I need is a networking solution. I must have the phoneline network still in the server for the basement computer. However, I do not want to use a router or hub.
I'm thinking of two possible solutions:
1)Put a second ethernet card in the server computer, and connect it to mine via cat5, and use a program like winroute.
2)Use some sort of USB network.
I'd rather to number 2, but how do USB networks actually work? Would it be feasible to get a double ended USB keyboard and connect the two computers, then use a software program to setup the connection? I also saw cords that had firewire on one end and usb on the other - my computer has both, but the server only has USB. If
If anyone knows how I could cheaply network the two computers via USB, help would be greatly appreciated.
