My friends computer is a AMD Athlon Thunderbird at 800Mhz. With a 100Mhz Front side bus. Does this mean that his 133Mhz SDRAM is only going at 100 because that is what the front side bus is? Or does the RAM run independant of the FSB?
Is it the same for my Pentium3 550E (5.5x100), because I have 128Mb PC100 RAM and want to know if getting 128 of PC133 RAM would make any difference.
Also, why do some people say athlons have 200Mhz system clock or something like that, is that because they are using the FSB and doubling it because there is both input and output?
Also, when will the Palimino be out, will it be 133FSB and will it be SocketA?
Thanks
Thanks
