Problem: Earlier today, after I restarted my computer, a popup told me something to the effect of (sorry, I don't know the exact wording) "a part of your registry had to be restored, the restoration was successful". I had done nothing out of the ordinary beforehand, so I do not understand what the point of this was. Now, there are several things wrong with my computer. First, Norton AntiVirus didn't work, and it suggested that I reinstall my Symantec products. So, I uninstalled SystemWorks 2003, AntiVirus 2003, and Internet Security 2003. I reinstalled all of them, but Internet Security still does not work, and I cannot figure out why. This is not all of my problem, however. Now whenever I open Internet Explorer, a page will load, and then the browser will hang and not respond or allow me to do anything. I have to do a Ctrl+Alt+Del and close it myself. In addition, I cannot open Windows Explorer, Help and Support, the Control Panel, and perhaps other things, I have not tried everything. It is vital that everything be back to normal, please help ASAP!
What I've Tried: I looked in the System Restore, but for some reason there are no restore points earlier than today, and those points are only because of the Symantec products I uninstalled and reinstalled earlier. I'm currently using Mozilla because Internet Explorer won't work, and using PowerDesk to access my files since Windows Explorer won't even open. I need these things working, however, there seems to be alot wrong and it needs to be fixed, please help.
That was yesterday, and the Dell tech support email response I got said to do a Repair Install, so I did, but it didn't help at all. The same problems still exist, and have not changed.
This sounds like a nasty virus. Take a look: a virus that recommends that you uninstall the virus scanner After reinstalling. Did you update your virus definitions a do a complete system scan?
<i><b>Engineering is the fine art of making what you want from things you can get</b></i>
<A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=655" target="_new">My systems</A>
I appears that somehow your registry has been corrupted. If reinstalling the affected apps doesn't make them work again, there is problably nothing else to do than reinstall windows.
I would've thought that a Repair Install would've been all that was needed, I certainly don't see what else could be wrong if it isn't the core Windows files that are restored in a Repair Install.
Certainly, a reformat and clean install would fix the problem, but it is an absolute last resort.
Any other comments and thoughts are always appreciated!
I have never had much faith in repair. Im not sure what else you can attempt. Perhaps a reinstall on top of the exixting. That may preserve your system settings and updates etc.
No. You just choose the option that say something along the line 'keep current filesystem intact'.
