Tom's Hardware > Forum > CPU & Components > CPUs > Does a Duron need a 300 WATT power supply?
Forum CPU & Components : CPUs - Does a Duron need a 300 WATT power supply?
I'm building a new computer, and was wondering if the Duron needed a 300 WATT power supply. I'm only asking because my local store has a special offer on a case with a 235 WATT power supply, which is considerably cheaper than the cheapest 300 WATT case. Also I have an old 1GB HDD, which works on PIO mode 4 with no DMA, will the HDD work with the new MoBo which states that it is compatible with PIO mode 4 with DMA-66 timings?
Thanx in advance
Dobo
Sponsored Links
My duron 650@750 works well with 250W PS, but not sure about 235W.
Reply to gong75
just buy yourself a 300watt p/s. it'll only set you back 30-40 bucks for a generic. that's still cheaper than buying a piece of sh!t p3. duron+300 or 433watt p/s is much cheaper.
fu(k intel.
If you can't beat 'em kill 'em
athlon "SLOTA" thunderbird 700@1050mhz
Reply to flavio321
It doesn't absolutely require a 300w power supply, but I would recommend you get one instead of anything lower.
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
Lets put it this way...extra power never hurts.
--SR
Reply to SoulReaper
(I don't know, sorry, try www.amd.com)
Buy that cheap case, and put there 250-300W p/s!
You probably will not regret this even if duron need only 200W.
All i can offer you is the truth. Nothing more.
Reply to Mordy
lol i just bought a case with 350w power supply that was actually cheaper then other 235w and 250w power supply + casing offers and yes it does work with AMd processors i payed roughly 75$ including shipping (dont know whetter this is cheap .. .its a maxitower.. Anyway the store i bought it from uses the same cases to build their own pc`s .. Which they offer to clients..
This was a dutch shop .. in dutch guilders i payed Fl. 165,-...
Yuo can find the store on internet aswell for those who are interested.
WWW.powerline.nl
Hey man i dont know .. i just think i do !!
Reply to Anonymous
Hi,
Latest IDE UDMA/100 controllers are backwardly compatable, so you should be able to use an old HD with no problem. PIO mode 4 ain't that old anyway :O)
My old Maxtor 540mb works on a modern controller no problem (er, aside from being a bit slow :smile: )...it is over 5 years old!
HTH
<font color=blue>Moots</font color=blue>
Reply to Anonymous
I installed the Asus A7V and Duron 650@900 in my old case with 235W and it works fine. However, if you plan to keep upgrading with the same case and ps I suggest you get at least a 300w. They are not that much more expensive and you will need it sometime in the future.
Reply to bsprawka
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
