Hl-dt-st bddvdrw ct21n problems
G
Guest
Guest
Hello,
My Blu Ray Drive doesnt play Dvds anymore....when i put it in the notebook just does a sound like hes trying to read it and never ends...hes fine with audio cds,cant try with blu rays since i havent got a single one here
i already tried upper/lower filter thing,i cant find any firmware updates or sth
can you help me?:)
What's the brand/model of your laptop? We can take a look around for a firmware update to see if that is the issue. Otherwise, I suspect that it may be a laser failure or something else on the drive itself.
G
Guest
Guest
Ah ok i finally found the model of the notebook..easy note LM87
