Solved
Help please triple monitor stand
was up guys will 3 of this monitor ASUS VH236H http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
fit with this monitor stand http://www.amazon.com/Triple-Monitor-Stand-Monitors-Clamps/dp/B003EE2AVG/ref=sr_1_9?ie=UTF8&qid=1341192645&sr=8-9&keywords=3+monitor+stand
to me on the back it looks like its a bit big its about 3.7- 3-9 inches and the stand shows 100x 100 mm idk what that's supposed to be.
9 answers Last reply Best Answer
More about help triple monitor stand
  1. the easiest way to "be sure" if a stand will fit or not is to make sure you buy a monitor with a "vesa bolt pattern" on the back. if you do then any "vesa mount" stands will fit without issue.
  2. That's not entirely true, because there are several different sizes of VESA mount, and you also have to consider the weight of the monitor(s). However, the Newegg specifications indicate the Asus VH236H has 100mm x 100mm mounting holes, and the stand supports both 75mm x 75mm and 100mm x 100mm mounting. The Amazon description doesn't give the weight limit for the stand, but this page does:
    http://www.outletpc.com/wq7222.html
    It says 22 lbs each, and the Asus VH236H is only 12.13 lbs, so that should be okay too.
  3. thanks i was going with the stand but i don't think i will be able to tilt the left and right monitor a bit to my face.
  4. Best answer
    I noticed that problem. If you haven't already looked at this one (that I found in the "also viewed" section), you might consider it as an alternative:
    http://www.amazon.com/Deluxe-Triple-Monitor-Desktop-Supports/dp/B006JG7G2E
  5. thanks that one it is .
  6. Best answer selected by ddp.
  7. hy @ MauveCloud look at this http://www.tykesupply.com/Products_Super_Triple_Monitor_Stand.html
    i was searching for some videos for the one u sent me and nothing but it shows on amazon that it does tilt so witch one would be better off the one you sent me or that one on top.
    looks like it does some info on the one you sent me http://shop.easymountlcd.com/Deluxe-Triple-Monitor-Stand-Desktop-Clamp-up-to-28-002-0019-002-0019.htm
  8. The one you started with might allow the monitors to swivel left and right, but without a forward and back adjustment, you wouldn't be able to set up a "cockpit" arrangement.
  9. so the http://www.amazon.com/Deluxe-Triple-Monitor-Desktop-Supports/dp/B006JG7G2E?tag=vglnk-c1001-20 it is i want a some what of a u shape but not completely so yea thanks again
Flat Panel Monitors Asus Monitors Peripherals Product
