G
Guest
Guest
Archived from groups: rec.games.roguelike.angband (More info?)
I am using SuSE linux 9.3 - x86_64(Athlon64) version and I am having
problems getting oangand to work.
I appears to compile ok, but when I try to run it, it freezes on the
more prompt after telling me that the save file doesn't exist. I tried
using an old save file, and it froze on the more prompt after restoring
dungeons.
I have compiled it ok on my old 32-bit laptop which also runs Suse 9.3,
but the 32-bit version.
Has anyone else had this problem? Do you know a way round it. I just
used configure followed by make with no options. I have gcc 3.3.5 and
automake 1.9.5 if it matters.
I have not had this problem with any other angband versions.
any help would be appreciated - my knowledge of how to compile things
is limited at best!
dungeons.
is limited at best!
