U unique1964 Honorable Jan 7, 2013 1 0 10,510 Jan 8, 2013 #1 Hello,my control panel shows' this file is empty' whenever i click n it. However I can see the organizer but they are not functioning. How do i get the control panel to delete fragment of java?
hedwar2011 Distinguished Dec 3, 2011 2,298 184 20,390 Jan 8, 2013 #2 If you are in Control Panel, are you able to search in the top right corner? If so, Search for Java. If not, I would recommend running either MalwareBytes Anti-Malwarehttp://www.malwarebytes.org/products/malwarebytes_pro/http://www.malwarebytes.org/products/malwarebytes_pro/ or Super Anti-Spywarehttp://www.superantispyware.com/http://www.superantispyware.com/ or even both because you may have something else going on that is causing all your issues. Upvote 0 Downvote
