What is the best 1920x1080 27inch monitor I can get?
Last response: in Computer Peripherals
http://www.kitguru.net/peripherals/monitors/zardon/asus...
http://www.digitalversus.com/lcd-monitor/asus-ve278q-p1...
http://www.computeractive.co.uk/ca/review/2113905/asus-...
http://hardforum.com/showthread.php?t=1546485&highlight...
The VE278Q is pretty good, but not the best 1080p 27". That would probably be this one given all your criteria (especially the work part and video editing part). Quite expensive for a TN monitor though (but you get what you pay for with NEC).
What extra features do you want? Do you want a VA or IPS panel, or do you want 120hz and active 3d? If you just want a simple 60hz TN panel, there are a lot of those without much difference between them.
Thanks for the replies!
I suppose a really sharp 27inch monitor..something solid and reliable. Really good picture. I hate 3D, but 120hz would be nice.
I guess what I am looking for is:
A solid, 27 inch monitor with the best picture quality I can get with a 2ms refresh rate. Any ideas?
Ask the community
