xp installation lockup help!
I'm upgrading from windows 98 to windows xp. It goes through its regular motions and then restarts. It asks where to boot from and I choose Windows XP Setup. The XP Logo screen comes up and then it says its looking at the computer components. Then it just locksup and shows a black screen indefinitely. Is there something I can do about that?
900 Duron
ECS K7VTA3 rev1.0
128 meg 2100 ddr
Maxtor 30gig HD
X-Wave 6000 Pro Sound Card
1 answer Last reply
More about installation lockup help
  1. I had the same problem a while back...
    It turned out to be my Geforce4 that was to blame, I replaced
    it with my old Geforce2 card and everything went fine.
    Now I just have to install SP1 and replace the graphicscard *sigh*
    What graphicscard do you have?
    <font color=blue>My sig, not yours</font color=blue>
Windows 98 Windows XP
