6 cell battery or 9 cell battery for this laptop?
Last response: in Laptops & Notebooks
i am about to buy this MSI GX660 laptop but one thing that concerns me is the battery. actually, just 6 cell battery is available right now in this model and i am a bit concerned as i am buying this laptop for gaming purpose only. so , do you think that 6 cell battery will do fine or 9 cell battery is a must for this laptop. Here are the system specifications: PROCESSOR: core i5-460M, RAM: 4GB DDR3(2GB*2), GRAPHIC CARD: ATI Radeon HD5870(1GB DDR5 dedicated graphics), CHIPSET: PM55, HARD DISK: 500GB SATA @5400rpm, SCREEN/RESOLUTION: 15.6" HD, Glare (1366*768) LED
Hello arpit_rathore7;
Won't you spend most of your gaming time plugged into the power grid? If so the 6 vs 9 cell battery won't be a factor.
Gaming on your battery? It won't last nearly as long as you'd hope, Im sure.
It looks like there is a MSI 9 cell battery available based on this webpage.
http://www.msi.com/index.php?func=prodnbspec&maincat_no...
You might be able to special order the 9 cell if it's critical to your gaming experiance.
Otherwise, maybe a 2nd 6 cell battery?
Ask the community
