Solved
Help choosing between monitors.
I'm buying a budget 1080p monitor and I have it down to...
HannsG hk241dpb
http://www.amazon.co.uk/HannsG-HK241DPB-23-6-Widescreen-Monitor/dp/B0063NWT2A
AOC i2352vh
http://www.amazon.co.uk/AOC-Multimedia-1920x1080-Headphones-Function/dp/B006W4Z2M4/ref=sr_1_1?ie=UTF8&qid=1343750503&sr=8-1
Which of the two is better value? They cost the same @130 pounds. I'll be gaming @1080p with light rendering for school.
Reasons behind your answer would be welcome.
6 answers Last reply Best Answer
More about help choosing monitors
  1. I would go with the ASUS VE228H. It's cheaper, has the same if not more features, and quality will be just as good if not better.
    http://www.amazon.co.uk/Asus-VE228H-Widescreen-Monitor-10000000/dp/B0043VPC0K/ref=sr_1_1?s=computers&ie=UTF8&qid=1343856413&sr=1-1
    Thank you for the link.
    I was hoping for 23- 24 inches and maybe ips, near ips clarity. Is it too much to hope for?
  3. What exactly is your budget? You can get a cheap IPS panel here:
    http://www.amazon.co.uk/Asus-VS229H-Widescreen-Monitor-Headphone/dp/B005HIRFYO/ref=sr_1_1?s=computers&ie=UTF8&qid=1343940954&sr=1-1
    If you're will to spend a little more look at the Dell U2212HM or the U2312HM:
    http://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Dcomputers&field-keywords=u2312hm&x=0&y=0
    (Both monitors show up in the search. the 22 is £163.39 + shipping and the 23 is £188.00 + shipping)
    It's in the first post as £130. The dell is too much. How about this?
    http://www.amazon.co.uk/gp/aw/d/B005UK3K8O/ref=redir_mdp_mobile?ref_=sr_1_6&s=computers&qid=1343964254&sr=1-6
    The price has dropped to £135.
    Thank-you for your assistance.
  5. Best answer
    I would say pick between the last one you posted and the ASUS IPS. Do some research on the iiyama and see if it has good reviews or not.
  6. Best answer selected by allanitomwesh.
Flat Panel Monitors Rendering Monitors Peripherals
