Tom's Hardware > Forum > CPU & Components > CPUs > Help with heatsink/thermal compound!
Forum CPU & Components : CPUs - Help with heatsink/thermal compound!
I removed the tape from the heatsink covering the compound and some of the compound remained stuck to the tape. Is this ok or will I fry my cpu? It looks like two little strips - probably about 10-20% of the compound is on the tape. I went ahead and installed the heatsink anyway...
The CPU is AMD 1.13GHz 266 FSB and MB is ABIT KT7A.
Any suggestions/advice?
Thanks!
<P ID="edit"><FONT SIZE=-1><EM>Edited by GhostBrain on 02/24/01 00:06 AM.</EM></FONT></P>
Sponsored Links
Not a problem as long as the compound is ditributed evenly across the CPU die once it flattens out from the pressure of the clip.
Suicide is painless...........
Reply to Crashman
I guess I have to assume that it spread out evenly. it left two small strips missing. i just don't want to kill my new cpu. thanks.
Reply to Anonymous
There are 579 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
