Reboot problem
when I want to install AVIRA this error is shown : "your pc isn't protected until reboot has been performed"
What should I do? Help me please :bounce:
6 answers Last reply
More about reboot problem
  1. Reboot your system!
  2. reboot.
    When a program makes changes to your registry, a reboot is needed to apply those changes. You will see this with updates as well.
  3. Thank you,I know all of them! I do that but after restarting system, that alert is repeated.
  4. Uninstall and then reinstall the software.
    I know, I did that! but the alert is repeated
  6. I had the problem with Avast so I quit using it.Now use AVG or MSE.
Windows 7
