F fierce Distinguished Oct 15, 2006 12 0 18,510 Jan 8, 2011 #1 I'm trying to remove the center panel of the R15S829 so I can replace the hinges on my clients Laptop, how do I do that? I dont want to try to pry it out with a screwdriver (flathead) and be sorry later. Any ideas?
Solution COLGeek Jan 8, 2011 Can you remove the backside of the LCD bezel? Looks like the thing you are trying to remove is firmly mounted.
COLGeek Cybernaut Moderator Apr 6, 2009 54,186 3,410 179,340 Jan 8, 2011 Solution #2 Can you remove the backside of the LCD bezel? Looks like the thing you are trying to remove is firmly mounted. Upvote 0 Downvote Solution
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jan 30, 2012 #3 Best answer selected by mousemonkey. Upvote 0 Downvote
Mousemonkey Titan Sep 3, 2006 59,466 17 92,965 Jan 30, 2012 #4 This topic has been closed by Mousemonkey Upvote 0 Downvote
