Dear users:
My name is Pablo and I'm fom Chile, so I will try to explain my problem with my best english.
Since a week ago I have problems with my mouse Razer Naga and my keyboard Razer Marauder.
When I open Razer Synapse 2.0 I'm stucked on a message: "Updating from Razer Synapse 2.0 Razer Naga", but the application is not updating and I can't do anything. Sometimes, I unplugged and plugged the USB cord and I reboot my computer and then the application works, but when I reboot the system again (with the USB cord plugged) the application is stucked again on the same message.
The curious thing is when Razer Synapse 2.0 opens properly the Razer Marauder driver do the same. But, when Razer Synapse 2.0 is stucked on that message, the Razer Marauder driver doesn't open neither.
I tried every single solution: Uninstall-reinstall mouse+keynoard drivers, uninstall-reinstall USB drivers, clean the RegEdit and a lot of more options.
I also contacted Razer Support for like 3 times before. Here is all the situation:
- First message to Razer Support (click the box to see it!):
- First answer from Razer Support (click the box to see it!):
* Second message to Razer Support (click the box to see it!):
* Second answer from Razer Support (click the box to see it!):
+ Third message to Razer Support (click the box to see it!):
+ Third answer from Razer Support (click the box to see it!):
So now I'm waiting for the last message from Razer Support.
I accept any kind of help, I really apprecciate it.
Thanks for all.
Hello:
My name is Pablo and I'm fron Chile and I will try to explain you my
problems with my best english.
I reinstalled Windows 7 Ultimate Edition 64 Bits and I finished the
installation with all the system drivers.
So, first, when I tried to use Razer Synapse 2.0 on my Razer Naga Molten
Core, the installation is completed but the program or interface is always
"frozen" on a message "Updating Razer Synapse 2.0 Razer Naga". I tried
with restarting my PC and reinstalling the program and drivers, but it
doesn't work. Everytime when I launch Razer Synapse, the interface is
always with the message: "Updating Razer Synapse 2.0 Razer Naga" and I can
not do anything on the program. My alternative solution for this was
download an older version of the driver, in this case, the Razer Naga Epic
3.02 without Synapse. I did the same, I installed the drivers and
restarted my PC, but when I want to launch the "Razer Naga Configurator"
the program/driver doesn't open and the program doesn't launch. The weird
thing is, when I unplugged the USB cord from the USB port the program
starts and I can use the software. But when I plugged again the USB cord
into the USB port and I restart the PC, the problem start from the
beggining again, the driver doesn't start and I can not do anything, is
always a cycle between: Not responding driver > I unplugged USB cord >
Driver starts > I can use the driver > I plugged the USB cord again > I
restart the PC > Not responding driver again......
So, second, I also have a Razer Starcraft 2 Marauder Keyboard and I have
the same problem that I have with the Razer Naga. I mean, I downloaded the
drivers, I installed the drivers and restarted my PC, but when I want to
launch the "Razer Starcraft 2 Configurator" the program/driver doesn't
open and the program doesn't launch. Is exactly the same like the Naga,
when I unplugged the USB cord from the USB port the program starts and I
can use the software. But when I plugged again the USB cord into the USB
port and I restart the PC, the problem start from the beggining again, the
driver doesn't start and I can not do anything. Same cycle between: Not
responding driver > I unplugged USB cord > Driver starts > I can use the
driver > I plugged the USB cord again > I restart the PC > Not responding
driver again......
I'm really sad about this because I'm a gamer competitor here in my
country and I can not use my gaming stuff as nice as possible.
I will be waiting for your answers and solution. I'm so stressed and
dessesperated and I really need your help and support.
Thank you for your time,
Pablo Acuna.
driver again......
Pablo Acuna.
Hello Pablo,
First, uninstall the Naga Epic driver. Then follow the steps below for Synapse.
Please try the following:
*Note: A second mouse is needed*
- Disconnect
- Uninstall Synapse 2.0
- Reboot
- Uninstall .Net Framework 4
- Reboot
- Run Microsoft Updates and apply all available updates for your operating system, rebooting when prompted (This may take some time)
- Install .Net Framework 4 -Standalone from the following links
(http://www.microsoft.com/download/en/details.aspx?id=17718)
- Reboot
- Right click on the Synapse 2.0 installer and choose "Run as Administrator"
- Reconnect
Next, follow these steps for the StarCraft driver.
1. Uninstall the driver
2. Reboot
3. Then enable compatibility mode:
1. Right-click on the installation file
2. Choose properties and you will see the Admin and Compatibility mode settings there in the Compatibility tab.
-Run it in Windows XP Service Pack 2 mode.
-Also in the Privilege Level section check the Administrator mode box
4. Reinstall by
1. Right-clicking on installation file and running it as Administrator.
5. Run configurator
1.By enabling compatibility mode on it as described earlier from the start menu Razer folder and enable administrator on it as well.
Please let us know if this helps.
Your customer number is 400911840
Please refer to case #:: 402397050 if you have any further questions.
If you need further assistance, you can also reach us online at http://www.razersupport.com. Please include all previous replies when/if responding to this message.
Best Regards,
Matthew H. at Razer Technical Support
support-us@razersupport.com
- Disconnect
- Reboot
- Reboot
- Reboot
- Reconnect
2. Reboot
4. Reinstall by
5. Run configurator
Best Regards,
Hello Razer Support:
My name is Pablo and I am from Chile. So, If you have someone spanish - speaker would be awesome.
My customer number is #400911840 and my case number is #402397050.
I got an answer about my Razer Naga Mouse and Razer Marauder. I did all the steps that you wrote on your last answer but I still have the same issue.
Razer Synapse 2.0 is still stucked on this message: "Updating Razer Synapse 2.0 Razer Naga" and I can not use my custom configuration. This also happens with Razer Marauder keyboard, the configuration program doesn't open. So, I'm stucked on the Razer Synapse 2.0 message and the Razer Marauder software that doesn't open.
But, when I unplug and plug the USB cords both sofwares opens automatically and I can use the custom configurations. But then, when I reboot my computer, the problem appears again in both devices.
So I'm thinking that would be a drivers issue with Razer Synapse 2.0 and not with the Razer Marauder driver, because the keyboard software doesn't open when Razer Synapse 2.0 is stucked on the message showed above. It is not a USB problem because all my others USB devices works great on the same USB ports.
Some days ago I got a message about the new update of Razer Synapse telling me that the autoupdate feature now will be manual. Is the new update on your website?
I will be waiting your answers and solutions. I need your help again!
Thanks a lot,
Pablo Acuna.-
Thanks a lot,
Pablo Acuna.-
Hello Pablo,
Razer only has English support.
Were you able to try reinstalling Synapse?
Did you set the Marauder configurator to open as an admin?
Lets try to reset Synapse and see if it helps with the issue for the Naga.
First I would like you to open up Task Manager and End RzSynapse.exe *32* Process.
Next Copy "C:\ProgramData\Razer" To your clipboard
Press Windows Key + R
-Paste into the Open field
-Press OK
-Delete the Synapse folder
Now go ahead and re-open Synapse from your start menu, You will be asked to log in again. And Synapse will go ahead and start re-installing all of its components for your device. Please make sure to click Ok on all the UAC prompts that will come on. One of them is tricky and will be minimized to the start bar as flashing shield.
Please let us know if this solves your problem.
Please refer to case #:: 402403583 if you have any further questions.
Best Regards,
William at Razer Technical Support
-Press OK
Best Regards,
Hello again Razer Support:
I'm Pablo from Chile.
My customer number is 400911840 and my case number is 402403583.
I got your answer about my Razer Naga and my Razer Marauder issues. I tried your last steps but I can't solve the problems.
Razer Synapse (including the last update that my system showed me today) is still stucked on the message: "Updating Razer Synapse: Razer Naga" so I can't use the custom configurations. It looks that is just a Razer Synapse issue because when Razer Synapse doesn't open, Razer Marauder neither. But when Razer Synapse open properly, Razer marauder do the same.
So, today I updated Razer Synapse with your last update and I get the same issue. Both drivers works fine at first, but when I need to restart my PC the message appears again and both drivers are stucked. I tried unplug and plug the USB cord again and the problem was fixed, but sometimes I unplug and plug and the stucked message is still on the driver. One time, I plugged and unplugged the USB cords and I opened Task Manager and I ended all the Razer processes and then I opened Razer Synapse again, and works (including Razer Marauder driver), but then I restart the PC and the message appears again.
I think is just a driver issue and not a hardware issue, because I have this problem with this 2 Razer peripherals and all my other stuff works great. I tried every single USB port with different peripherals and all USB ports works perfect. I also tried install-uninstall USB drivers. Same with the Razer drivers, like for 10 times before.
I will be waiting your help again.
Pablo Acuna.-
Pablo Acuna.-
Hello Pablo,
Thanks for contacting Razer. We have escalated your issue to a specialist who will personally handle your case and get back to you shortly. While most escalations are answered within one to two business days or less, some escalations can take a bit longer due to the nature of the escalation and/or during peak customer demand. We appreciate your patience.
Please refer to case #:: 402405834 if you have any further questions.
Best Regards,
Terrell at Razer Technical Support
Best Regards,
Thanks for all.
