" However, the walls of a jet engine need to be kept cool as they are joined to the wing of the aircraft where the fuel is normally stored – laminar flow is used in keeping things cool."
The "walls" of most current type jet engines are in no threat of getting very "hot" what with 90% of the thrust being developed by Bypass air rushing past a suspended core. You bet your bottom dollar that's it's 1000deg in the can, but with engines developing 35k-100k of thrust on modern bypass engines cooling takes care of itself *especially @ 35,000 feet at -60*. What I am trying to say is that "Thrust the byproduct of the work of the engine is used to keep the outside of the core cool...not laminar flow per se', Also the flow past the core is not really laminar, as there is too much parasitic drag and form drag, also don't forget the eddies created by the movement of the blades themselves....though tip drag is kept in check by the engine shroud itself. So what I am trying to say is that it's like they thought they would find the coolest term....find examples in current technology and then try to sell the concept with it. It's cheesy. On the other hand, a Laminar flow Wing or Planform is a far better example of Laminar flow in fluid dynamics. Relating it to engines while technicaly true is kinda like trying to make the Egg fit in the goose.
