B Bert185 Distinguished May 5, 2010 4 0 18,510 May 5, 2010 #1 Hello, I have tried 2 WLAN adapters in my desktop PC (one card and a USB), running W7 64-bit ultimate. Adapters are recognized, drivers installed, shown. But I cannot get them to switch one! Wired works fine. What can I do?
mi1ez Splendid Jul 17, 2007 4,771 1 23,160 May 5, 2010 #2 Are you trying to switch them on using Windows' tool or using a program that may have been installed with the driver? Upvote 0 Downvote
B Bert185 Distinguished May 5, 2010 4 0 18,510 May 5, 2010 #3 mi1ez : Are you trying to switch them on using Windows' tool or using a program that may have been installed with the driver? The Windows tool. Upvote 0 Downvote
mi1ez Splendid Jul 17, 2007 4,771 1 23,160 May 5, 2010 #4 See if the driver installed a program of it's own and that works. Upvote 0 Downvote
B Bert185 Distinguished May 5, 2010 4 0 18,510 May 5, 2010 #5 Nah, that makes it worse. It seems Win 7 doesn't like these WLAN utilities - anyway, tried it and it doesn't work. Upvote 0 Downvote
B Bert185 Distinguished May 5, 2010 4 0 18,510 May 5, 2010 #6 ok, solved it! In properties of the adapter, my virus checker's filter (Kaspersky anti-virus NDIS 6 filter) has to be switched off... Upvote 0 Downvote
Gandalf Distinguished Dec 12, 2009 1,303 0 19,460 May 5, 2010 #7 Bert - FYI - virus checkers often not only block viruses but also block things you want to do. Glad to see you solved the problem. Upvote 0 Downvote
