3D Monitor or Large Monitor?
I will soon be finishing up my build, and I was originally going to get a Asus VG278H 3D Vision 2 monitor, but now I'm wondering if I should just get something like a 30" monitor for a higher resolution.
I've never tried an 120Hz screen before, and I don't know if it will be as good as people say in the long run.
I'm really interested in 3D Vision, the only thing that makes me weary is the lack of people who use it, and the people who say negative things about it, and how it gets boring after a while.
The 3D monitor itself is 27", so I'm not really sure if the 3 inch difference and the higher resolution would be worth losing 3D and 120Hz.
Also, I'm not looking to spend an obscene amount of cash for a 30" monitor.
Any suggestions?
7 answers Last reply
More about monitor large monitor
  1. I've continued to look into it, and I'm now deciding between a higher res or the 3D monitor. So it's come down to these:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236206
    and
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824260038
    both are 27", but the second one is 2560x1440, while the first one is 1920x1080, but supports 3D and 120Hz.
    My current monitor is 1920x1080 and is 23.6". Would the 27" 2560x1440 be a big upgrade and worth the cash? or should I go with the other monitor?
  2. This topic has been moved from the section Graphics & Displays to section Computer Peripherals by Mousemonkey
  3. I personally chose 3D Vision and glad I did. 3D is pretty awesome when the game supports it, which more games do these days.
    Yeah, I wish someone who has had both would answer...
  5. I have only seen one person on these forums who has used both, and that's JackNalor (might have that spelled wrong), and he has recommended 120hz and 3D in the past. You can do some google searches, there are people out there who do respond. Unfortunately, there aren't a lot with both on this site.
    Eh, I think I might be leaning towards the 3D monitor more, since it's also a lot cheaper at the moment. The only thing that makes me weary about buying it is the lack of people who support it...
  7. This might help you with support: http://helixmod.wikispot.org/gamelist
    That modder has a lot of fixes and a program to fix many games.
    With it, I'd guess nearly half my games support it.
Flat Panel Monitors Resolution Monitors 3D Peripherals Product
