Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > [Solved] Strange Thinkpad T41 Video problem
Forum Laptops & Notebooks : General Discussion [Solved] Strange Thinkpad T41 Video problem
Best answer from mavroxur.
Here are the facts:
My TP T41 LCD is dark. Shine a light on it and you see dim video.
When plugged into an external monitor I have a Great picture. (Indicates a good video chip)
I took the entire panel off and put in on another T41 and it works great. (indicates a good LCD, inverter and backlight)
Re-install on original laptop and it's dark again.
When I hold my frequency meter near the inverter there are no oscillations, on the working system I measure 68.2 Mhtz.
If I manually operate the lid close button, both the LCD and external monitor go dark. I release the button and the external monitor returns to a nice bright picture. The LCD returns to the very dim picture. (indicates a good lid switch and proper sleep functions)
I'm STUMPED. Anyone have an idea?
Thanks!
Reply to eudaly
Best answer
If you're also swapping the cable that goes from the lid to the motherboard, it sounds like your motherboard is no longer providing either the +5v for the inverter, or it's not sending the signal to turn the inverter on. I've seen it happen on a compaq before where the MB would no longer send a power-on control signal to the inverter any more.
Reply to mavroxur
That's what I concluded as well. Problem is, I have no idea how the 5volt is supplied.
There is only one cable to the display so the 5 volts is supposed to be on a pin in the connector... but which one. (The cable was swapped with the lid)
Thanks for your reply.
Cecil
Reply to eudaly
Inverter or back light fault. Most likely the back light which means a new screen.
try www.rolta.co.uk.
I probably fix around 5-6 machines a week with back light faults.
Reply to plasmastorm
If you would've read the original post, he swapped the entire lid to another laptop and it works, so that proves his LCD, cable, inverter, and blacklight tube are all good.
And yes, the +5 is a certain pin on the cable. Just look at the inverter, it should only have 4-6 wires going to it, and looking at the traces, it's easy to tell what does what. Usually the +5 pins on the inverter lead to a small surface mount fuse before going to the chopper. The grounds are pretty obvious. And 1 or 2 pins will have a very small trace that usually leads to the PWM/Oscillator IC, those are the logic turn-on signal line(s).
Reply to mavroxur
I agree, the 5 volts should certainly be on the cable attaching to the inverter board. But.... the cable to the board is a flat ribbon with 24 conductors. (the inverter also has 7 LED's for power, charge, wireless, sleep, caps, num and disk). I have a schematic for the T41 but it doesn't include the display circuitry.
Probably should just junk the thing but... I'M STUBBORN!! :-)
Cecil
Reply to eudaly
Cecil
If you're stubborn, i'm assuming that you'll be getting after it with a DVM and getting back to us with the results of what you found :-)
Reply to mavroxur
yep... the old eyes make it difficult but i'm a tryin'
Reply to eudaly
well... I found the problem. It was a small fuse (about the size of a black pepper flake) on the motherboard. I took a fuse off of another motherboard but lost it in the carpet before i could get it installed. I successfully suppressed the urge to throw things and put the carcass in a box under the bench. (That's the first stage of throwing it away).
Reply to eudaly
BTW, I like the Youngster tag.... cause I'm pushing 70 :-)
Reply to eudaly
Well, fuses generally aren't black. If it looks like this....
http://commons.wikimedia.org/wiki/ [...] sistor.jpg
It's not a fuse, it's either a transistor, FET, or something similar.
http://www.littelfuse.com/data/en/ [...] _HiRes.jpg
or looks similar, it's a fuse. A fuse will only have 2 leads. If it has more, it's not a fuse. The reason I mention this is because SMT fuses generally aren't black, and not the size of pepper flakes. SMT transistors are though.
Reply to mavroxur
I didn't mean to imply that the color was black, only that it was small like a black pepper flake.
Thanks for your concern.
Cecil
Reply to eudaly
There are 2013 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bios passwort vergessen laptop acer Extensa 5220
By Brett928S2, 1 hour ago:
Hi :) We are NOT allowed to help with passwords here at Toms... All the best Brett...
Best offers
Top experts
