Solved
HP w2207 22" Will it work with my new build? GeForce 660 Ti
I have a HP w2207 22" Widescreen flat panel monitor (RK282AA) (1680x1050 @ 60Hz Max)
Video input connector: Digital (DVI-D with HDCP) and Analog (15-pin D-sub VGA)
http://h10010.www1.hp.com/wwpc/ca/en/ho/WF06b/12142134-12142242-12142244-12142244-12142244-79803167-79803596.html?dnr=1
I've had this monitor for a few years. Didn't use it much. I'm ordering my first gaming pc build tommorrow, and would like to know if this monitor will perform well with my build, and which cord I need to purchase.
Here's my build:
CPU+GPU Combo Deal:
-Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
-MSI N660 Ti PE 2GD5/OC GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
-http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1050224&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=1q7umzop22ko8
=520$ with 10$ MIR
Mobo: ASUS P8Z77-V LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard - 190$
http://www.newegg.com/Product/Prod [...] 6813131820
+FREE RAM: G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
http://www.newegg.com/Product/Prod [...] 6820231546
Operating System: Microsoft Windows 7 Home Premium SP1 64-bit - OEM 100$
http://www.newegg.com/Product/Prod [...] 6832116986
PSU: SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply - 140$ (15% off with promo code SSPSUSEP12, ends 9/10) = 119$
-I agree it's slightly overpriced, but SeaSonic is by far the best brand for PSU, also has 5 year warranty
Cooler: Cooler Master Hyper 212 EVO CPU Cooler with 120mm PWM Fan - 31$
http://www.newegg.com/Product/Prod [...] 6835103099
Optical: ASUS 24X DVD Burner - 20$
http://www.newegg.com/Product/Prod [...] r4gszxtbea
Case: Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811139009 - 115$(after rebate 95$)
SSD: SAMSUNG 830 Series MZ-7PC128B/WW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Prod [...] 6820147163 - 100$
7 answers Last reply Best Answer
More about w2207 work build geforce
  1. yes it will work. anything with dvi will work
  2. But which cord do I purchase if the monitor has Digital (DVI-D with HDCP) and Analog (15-pin D-sub VGA) slots?
  3. DVI-D male to male.
  4. Can someone confirm this from the specs provided above?
  5. Best answer
    Already did. If your question is what cable to use its DVI-D male to DVI-D male and yes, that monitor will be fine with a GTX 660 Ti. I had a w2207h (HDMI version) and it was fine with my GTX 670. Just got a larger monitor a month a go to replace it.
  6. I appreciate it man.
  7. Best answer selected by hmille0.
Flat Panel Monitors Hewlett Packard Peripherals Product
