Advice on which monitor to buy
Hi
Wondering if people here can help me decide on a monitor. I use a PC for gaming on and have a MacBook Pro for everyday use, web design and programming. I want to hook the two up to one screen but I cannot decide if I would be better going for IPS or TN with 120Hz as both come with their own advantages and disadvantages.
Two monitors have my eye on are:
Dell U2713HM - Good IPS I believe not much ghosting and the anti-glare coating is much less than the old model although response time is now 8ms instead of 6 but I don't think it will be noticeable?
http://www1.euro.dell.com/content/products/productdetails.aspx/dell-u2713hm?c=uk&l=en&s=dhs&cs=ukdhs1&baynote_bnrank=0&baynote_irrank=0&~ck=baynoteSearch
Asus VG278H 3D - I like the Samsung ones but they are restricted in that they aren't very adjustable and Nvidia 2 3D on this monitor too
http://www.amazon.co.uk/Asus-VG278H-LightBoost-1920x1080-Dual-link/dp/B005XA2COO/ref=sr_1_1?ie=UTF8&qid=1347825580&sr=8-1
So what I want to know is should I go the IPS or 120hz TN route baring in mind I do use the PC for gaming so response and lag times need to be considered.
Thanks
1 answer Last reply
More about advice monitor
  1. Forgot to mention (can't seem to edit post)
    My PC spec is:
    Intel Core i7 930 2.8GHz
    6GB DDR3
    ATI Radeon HD 5870
    24 inch Acer 243HL (TN panel)
Flat Panel Monitors Gaming Monitors Peripherals
