Hey peeps,
I had previously posted on here regarding what I thought was a graphics problem (http://www.tomshardware.co.uk/forum/forum2.php?config=tomshardwareuk.inc&cat=15&post=368736&page=1&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0"e_only=0&new=0&nojs=0). But it turns out it was my monitor after all.
So I have a new monitor: Samsung S22B300HS 21.5 inch Widescreen LED Monitor - Gloss Black (1920 x 1080 Full HD, 5ms, HDMI/VGA)
The problem I'm having is trying to get the best quality display from it, particularly for gaming. I find the callibration overly complicated and so far, I'm not at all happy with any of the displays I've experimented with. I had initially tried to use some Samsung software called MagicTune, but that doesn't work at all. I believe it's actually not compatible with this monitor, nor my graphics card (ATI Radeon HD 5800 Series). I then also tried setting up the monitor through ATI's Catalyst Control Centre. I had what I believed was a better quality picture.
While the display on my desktop and browser looks fine to me - I log on to World of Warcraft and the colours are terrible! The text is all fuzzy and the colours are overly bright, it really is an eyesore! A friend of mine asked what cable connection I'm using - I said the HDMI cable. I bought a HDMI - DVI converter so that I can connect it to my graphics card. He believes this could be the problem and that maybe I'm better off using the VGA connection and buying a VGA-DVI converter instead.
So two questions to any kind soul out there...
1. Should I change the cable from HDMI to VGA?
2. Does anyone know of perhaps a software that allows you to have different monitor profiles? Unless of course, the cable issue is the problem and might just fix all.
Many thanks!
Many thanks!
