Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
Actually its on page 30 of the manual. But here is what
it says:
I can't stay connected to my wireless network.
If you are running Windows XP operating system with
Service Pack 1, you might lose connection to your
wireless network every 3 to 5 mins. This can be caused by
incorrect wireless network security settings. To solve
this problem, you need to disable 802.1x authentication
on your wireless network, as described below.
To disable 802.1x authentication in the Win XP O/S
1. click start, point to connect to, click show all
connections, and then double click your wireless network.
2. on the general tab, click properties
3. click the wireless networks tab.
4. under preferred networks, click your home network, and
then click properties (THIS IS MY ADDITION: make sure to
check the box beside: use windows to configure my
wireless network settings. If you do not, you can not
access the preferred networks properties anyhow...how
silly.)
5. click the authentication tab, and then click to clear
the enable ieee 802.1x authentication for this network
check box, if its selected.
6. if you cannot click this check box, then you are not
using 802.1x authentication or wireless security.
Anyhow, it worked for me on Win XP Pro with SP2
installed...
Thanks for the lead in the firstplace.
Drew
>-----Original Message-----
>I was experiencing frequent drops from my wireless
also.
>Followed the suggestion on page 42 in the MN-700 users
>guide to disable 802.1x authentication in Windows XP.
>Problem solved!
>>I have a Microsoft wireless internet access kit set-up
>in my apartment to
>>access the internet. I have a MN 700 base station and
MN
>720 wireless access
>>card. Both meet the 802.11g standards. I have setup a
>small home network to
>>share the internet access between two laptops. Both the
>laptops have same
>>wireless access card (MN 720). I have been having lot
of
>problems in
>>accessing the internet.
>>I cannot remain connected to the internet more then one
>hour continuously.
>>After every 30 minutes or so i have to actually
>disconnect the power supply
>>for the base station to reset the base station. I tried
>chaging the security
>>key authentication to a 16 bit and also tried turning
>security off
>>completely. I then tried changing the channel for my
>wireless netwrok as it
>>could interfere with neighbouring cordless phones. I
>tried channel 3,6,9,4.
>>All of them gave the same result. And they cause the
>same trouble on both
>>the laptops. Both laptops are running Microsoft windows
>XP home edition. I
>>am really frustrated with the current problem. Every
>half hour or so go and
>>reset the base station , how ridiculous? I think i was
>better of buying a
>>wired router rather then going wireless but i already
>invested my money and
>>now i am stuck. Can somebody help me ???????
