Razer Mamba right click is going
Been having a problem with my right click, sometimes it works and sometimes nothing happens. It also depends where I click, does anyone know if this problem can be fixed?
3 answers Last reply
More about razer mamba click going
  1. You're not awfully specific about the problem, but anyone would tell you to update the drivers and firmware to see if it fixes it.
  2. something i noticed with mine is that if you take it apart with some how to guides on youtube, you can see that the joint pressing down on the button is slightly raised compared to the other button, either from wear or design the button eventualy seems a little to short, I applied a small layer of super glue to make up for the gap and it worked good
  3. I applied a small layer of super glue to make up for the gap and it worked good
Razer Peripherals
