Solved
USB Cable for color laser printer
Last response: in Computer Peripherals
September 21, 2012 8:12:10 PM
Hi guys, I was wondering what kind of USB cable is needed for a color laser printer.....seems like the one I bought doesn't come with one :/
I was wondering if the USB cable I have for my inkjet will work with the laser printer.
Thanks!!
Best solution
September 25, 2012 7:58:28 PM
It should work, unless it is a VERY old USB 1.1 cable.
September 25, 2012 10:55:09 PM
thanks, the cable fit :D  ~
m
l
Best answer selected by qiwibunni.
m
l
