Basically I have frequent lockup problems with Windows XP.
What I have done:
Installed XP with a Geforce2Mx card and without SB5.1 because it would not install with my Geforce4 card (The SB5.1 card I ripped out just to be on the really safe side)
Installation went fine from here and I downloaded and installed SP1 which also installed without problems.
After everything worked nicely I put the Ti4200 and the SB5.1 back in...
However, my system seems a little bit unstable...it lock up whenever it feels like it, for example surfing or just browsing Explorer.
So far I have installed drivers for the SB5.1 card (XP took care of that) and I have installed the latest detonators.(I got a message that my Ti4200 not was 'tested' yet by Microsoft, whatever that means...thousands of people have the card and obviously it´s working with XP)
As for the 4in1´s I´m quite unsure of what to do...I´ve heard that you don´t need to install them as they are 'built in' XP...what if I want to upgrade then? sounds lame so I installed the latest version anyway :tongue:
Specs:
XP1600
Epox 8KHA+
Ti4200, 128Mb (ASUS)
512DDR
SB5.1
IBM60Gxp and WD(8mb version, always forget the name of it)
Hmm...I hope I didnt forget to mention anything now.
If you have any ideas then please let me know.
<font color=blue>My sig, not yours</font color=blue>
What I have done:
Specs:
XP1600
Epox 8KHA+
512DDR
SB5.1
