Solved
$150 23" Monitor for all-purpose/gaming usage! (: Help, please.
Last response: in Computer Peripherals
September 29, 2012 2:46:08 PM
Hey! I'm looking for a good $130-$150 22"-25" (23" ideally) monitor for my new build that I will be getting relatively soon. I already have one idea, as well as some questions and I would appreciate if you read and/or answered them for me. Thank you. (:
My idea: Acer S231HLbid 23.0" Monitor ($149.99 @ Newegg)
Usage from greatest to least: Chrome web-browsing, YouTube, Gaming, Office applications, watching movies & shows, Photoshop, etc.
Questions
1) Is my pick 100% fine for what I would like to use it for?
2) What are your suggestions?
3) What does one look for in a monitor?
3a) For gaming?
3b) For photo-editing (Photoshop)?
3c) For all-purpose?
4) Is there any compelling reason that I should bring up my budget?
Thank you so much for answering any of these questions, and have a great day!
My build (WIP)
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($190.39 @ NCIX US)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($87.55 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Video Card: Sapphire Radeon HD 7770 1GB Video Card ($134.99 @ Newegg)
Case: Antec Three Hundred Two ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: Corsair Builder 600W 80 PLUS Certified ATX12V Power Supply ($51.98 @ Newegg)
Optical Drive: LG GH24NS90 DVD/CD Writer ($17.99 @ Amazon)
Total: $642.87
Best solution
a b C Monitor
September 29, 2012 8:26:49 PM
Mostly.
If your going to do a lot of things that require a color-accurate monitor, this isn't it.
3a) For gaming?
TN panel and input lag.
Color accuracy, wide gamut, and color profiles.
Reliable, inexpensive, LED-lit
Depends on what your primary use is. Photoshop will not like the monitor you have currently selected, it thinks the color profile is wrong.
September 29, 2012 9:07:49 PM
Mostly.
3a) For gaming?
Do you have any other monitors in mind? Photoshop will not be my primary use, not even close, but I would still like it to function nicely... I have been using an outdated eMachines monitor for photoshop. Four years old at least. Do you think that the monitor I picked will be better than that for photoshop? Is there any way to make it think the color profile is right?
Current monitor: eMachines E19T6W 19" Monitor
m
l
a b C Monitor
September 29, 2012 10:13:01 PM
Without knowing your budget I can't say for sure.
Well I have the monitor your looking at, although I paid more for at the time. As far as color profiles go, you could make a custom profile for it, but for the most part it's minor.
m
l
September 29, 2012 10:37:42 PM
Budget is around $140, give or take $10 (give $20 - only if it's REALLY worth it).
Thanks for your help.
m
l
September 30, 2012 12:09:43 AM
sk1939 said:
This would give you a better picture, but it's $30 above budget, and 3" smaller than your current display: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
This would also be a step up, but it's again $100 over budget: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
A wide-gamut monitor (large color range) would set you back $450 at least.
Thanks! I appreciate all of the help and knowledge that you've given. I think I'll just stick to the monitor I have picked. If there's problems with the colors/picture, you said that I could make a custom profile, so if it comes to that, I will. Have a wonderful evening.
m
l
September 30, 2012 12:10:01 AM
Best answer selected by HigginsHere.
m
l
