Monitor blink says " auto adjustment in progress"
Last response: in Computer Peripherals
October 19, 2012 7:36:52 PM
core 2 duo 2.9 ghz
3 gb ddr 2 ram
xfx 9800gt
cooler master 460 watt psu
win 7
monitor: HPw1907
Since last night my monitor randomly blinks and says "auto adjustment in progress".
When I shut down and then starts after few minutes it runs ok for about 30-40 mins but then again starts blinking.
Is there any way i can disable auto adjustment on my monitor.
waiting for ur reply
a b C Monitor
October 20, 2012 2:01:04 AM
That sounds like the monitor is failing.
m
l
October 23, 2012 6:38:30 PM
I replaced the vga cable with a dvi cable and auto adjustment stops
m
l
a b C Monitor
October 24, 2012 3:16:21 AM
OK, then the VGA circuit has failed. I had that happen on a monitor two years ago. After I switched to the DVI connection it worked fine, and still works fine today.
m
l
