Closed Solved
BSOD HELP~!
Hello,
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
IRQL_GT_ZERO_AT_SYSTEM_SERVICE
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000004a (0x000000007782138a, 0x0000000000000002, 0x0000000000000000,
0xfffff8800b325b60)
please help
29 answers Last reply Best Answer
More about bsod help
  1. what are you doing when this occurs? it is difficult to determine a problem based on complex file names and error numbers
  2. it always happens when im playing games mainly League of legends... i usually know how to fix my bsods but this one i have no idea... all drivers are up to date... no new hardware...
  3. What GPU are you currently using?
    I had a similar problem when i overclocked my gtx 570 too far and wrecked the voltage regulators on it. Do any other screens flash ? i.e Pink or green?
  4. No screens flash im using a nvidia 555 i never have any other problems its only when i play league.
  5. Yeah i used to only get the crash on halo custom edition. i swapped out my video card and the problems ended. do you have a spare GPU you can use to test?
  6. no i cant swap my GPU out its built into my laptop, lol sorry i should have mentioned that. but i don't think its the GPU only because its barely a year old, and it didn't happen before i played league.
  7. that would have helped haha :)
    erm, you could try updating your chipset drivers and such. what model is your laptop?
    EDIT: Was the problem immediate or did it take a while to develop?
  8. Its a dell XPS 17 (L702x). My NVIDIA drivers are up to date.
  9. could you post your hardware info by any chance?
  10. Operating System
    MS Windows 7 Home Premium 64-bit SP1
    CPU
    Intel Core i5 2520M @ 2.50GHz
    Sandy Bridge 32nm Technology
    RAM
    7.89 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
    Motherboard
    Dell Inc. 0XN71K (CPU) 54 °C
    Graphics
    Generic PnP Monitor (1920x1080@60Hz)
    NVIDIA GeForce GT 555M
    Intel(R) HD Graphics 3000
    Hard Drives
    488GB Seagate ST9500420AS (SATA)
    Optical Drives
    TSSTcorp DVD+-RW TS-L633J
    ROXIO DVD-ROM EMULATOR SCSI CdRom Device
    Audio
    High Definition Audio Device
    Is this what you wanted?
  11. Best answer
    yes thanks.
    I Googled you laptop and found its using the Intel HM57 chipset.
    go to this link and download and install the latest chipset drivers.
    i asked earlier but i think you missed it, was the problem immediate or did it develop over time?
    link: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Mobile%20Intel%20HM57%20Express%20Chipset
  12. Are you using the video drivers from AMD/Nvidia? or the recommended video drivers from your laptop's manufacturer? Update to the latest (if you haven't already), try the manufacturer's if you are using the vendor's drivers or the vendor's if using the manufacture's.
    I've had similar problem's with laptop video drivers and particular games "triggering" BSOD's and other strange behavior.
  13. +1 to that.
    Change things around a bit, it may just be a certain driver disagreeing with a new update of LoL or something.
  14. Quote:
    link: http://downloadcenter.intel.com/Se [...] %20Chipset
    It developed over time... idk if its getting more frequent but it seems like it
    I went to the link and installed the updates. Ill get back to you here about the problem if i see improvement or if its still happening.
    How do i check to see if something isn't agreeing with something else?
    Thanks
    TechPanda
  15. Quote:
    This is the tricky part. Trial and error my friend, it will take some patience. Just try older video drivers or await an updated release. It does sound graphics related.
  16. Ok thanks ill reply within a week and let you guys know
  17. Huh, I don't see that BSOD that much; IRQL_NOT_LESS_OR_EQUAL is FAR more common...
    Either way, IRQL BSOD's are "typically" due to either a bad driver, or bad RAM. Run memtest86+ for a few passes and make sure you get no errors.
  18. Ok i will do that today
  19. Ran the memtest.. no errors.. made like 5-10 passes... the bsod just happened again today.. any ideas?
  20. try to "roll back" your driver to use a previous driver.
  21. lol how? i would have no idea.. where to start
  22. right click computer, manage, device manager, that's where we usually update or roll back drivers
  23. If its not RAM, then its probably a bad driver. Knowing which one it is though is going to be a problem...
    Download BlueScreenView and post a screenshot. [Photobucket preferred; my workplace blocks everything else].
  24. ok so the first one is this link
    I found another one.. idk if its related
  25. bump
  26. probably a bad driver, check again if there are any updates for most of your components
  27. I have monitored this for anwhile and i havnt ha any problems must have been one of the steps up there^^ thanks so much guys
  28. Best answer selected by TechPanda.
  29. This topic has been closed by Brett928S2
Software Blue Screen Computers Windows 7
