Solved
Monitor Suggestions for parts list
I have an almost completed parts list. Just missing the monitor. Was thinking of the Asus H236H: http://www.asus.com/Display/LCD_Monitors/VH236H/#specifications
Couldn't find a standard form for asking so here goes:
Price Range: <$150
Size: 23" or so
Resolution: 1920x1080 (1080p)
Primary use: Gaming
Current Parts List: http://pcpartpicker.com/p/l9vm
-CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor
-CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
-Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard
-Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory
-Storage: Samsung 830 Series 128GB 2.5" Solid State Disk &
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
-Video Card: Sapphire Radeon HD 7970 3GB
-Power Supply: PC Power & Cooling Silencer Mk II 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply
6 answers Last reply Best Answer
More about monitor suggestions parts list
  1. This topic has been moved from the section Graphics & Displays to section Computer Peripherals by MouseMonkey
    Sorry, didn't know this section existed.
  3. Best answer
    The Monitor you listed should be OK
    By OK do you mean that there could be better options or that I should just go with this one. If so I would appreciate it if you could list maybe one other one, just to compare.
    Thanks
  5. Best answer selected by Blue0ak.
  6. I am sorry i never replied. You found the answer you were looking for though right?
Flat Panel Monitors Peripherals
