So My AMD Phenom II x4 965 BE was hanging now and then. I decided to update the bios for stability with OC. Bios were a fairly old version on the ASUS M5A97 MOBO. All went well - no more hanging while OC'D.
Now for the fun stuff. My computer starts normally but My D-Link Extreme N Wireless Adapter Is not installed. It is now called "Ethernet controller". The only way for me to install the driver is by me physically unplugging the PCI adapter (The D-Link) and plugging it back in while the computer is on. It also instructs me to do this in the D-Link driver installation.
This works and the internet works enough to browse and torrent BUT if I restart my computer the same thing happens again. Found device "Ethernet controller"... Gotta unplug/plug it back into the PCI seat and install the driver. So I learned to live with this by never turning the computer off. I just put it into sleep overnight.
My problem is though it seems the stability of the connection is complete $#^&. Playing games my ping goes up and down all the time and hangs and just isn't playable.
I know enough to check my wifi channels and settings and sniff around. I live in a rural area - there are no other wifi signals around. Just mine. No one else uses the internet. I even called the provider up and everything is just great 15mb connection. I do a speed test to somewhere local and get 16mb/s down 2.5 up 30 ping. What in the hell is going on? There are no PCI settings in the bios I checked everything in there.
