Okay. So I'm going insane trying to figure out what's wrong with this computer! I've reinstalled Windows 3 times now, and I don't know what's wrong. I'm thinking it's a hardware problem, but I need opinions.
Okay here's what's going on guys. I recently just built a new computer, which I asked for help here, and took most of the advice, but made a few different decisions on my own). I do not have a working DVD drive because the one I bought ended up not working. It works, but the tray will not open when you press the eject button. So I left it. I didn't want to take the computer apart again considering I had to take it apart a few times after building it to get some things right. Here's EVERYTHING that's happened so far so maybe someone can figure out what's go on.
First installation of Windows 7: So I put Windows 7 on a USB stick. I had to go out for a while, so I shut it down right after installing Windows 7. I did not put any drivers on it or anything. So the next time I go to boot it up, it just hung on the Windows logo screen. So I tried to boot into safe mode. At first I thought that wasn't working either, until I checked on it again around 10 minutes later when safe mode finally loaded. I try to do something, and it runs really slowly and pretty much locks up (running so slow it can't load anything). So at this point I decide to remake the USB stick and reinstall Windows 7.
Second installation of Windows 7: I wipe the hard drive and reinstall Windows 7. I put Daemon Tools Lite on a different USB stick and install it. I made copies of my driver disks and copied them to an external hard drive. So I used Daemon Tools Lite to install my drivers. Everything worked fantastically! So by this point I had mainly just been rebooting. I do turn off the computer so I can get to the back to plug in my ethernet cable. I turn it back on, update Windows, and install a bunch of random things (Malwarebtyes, Firefox, Avast, etc.). So it seems my computer is good to go. The next day I turn it on and decide to install Microsoft Office 2007. I leave it for a while, and the installer for Office gives me a weird error. So I try to close it, and it says removing backup files. Everything's still running, but nothing is loading. So I try to ctrl + alt + del, and nothing happens until about 2 minutes later my screen goes completely black except for my mouse cursor. I let it sit for around 2 or 3 minutes before I just turned off my computer. So I boot it back up and everything seems fine until about 3-5 minutes later, everything starts freezing. It's funny, because I can run my mouse over icons and the highlight animation is not slow at all. I can also move windows like they are nothing. But I can't close or do anything with any program I run. It will finally either close or do whatever I was trying to do, but it takes like 2 or 3 minutes just to do it. The next time I try something, it'll freeze again and then finally do it around 2 to 3 minutes later. I decide to install Windows again, thinking I did something wrong.
Third installation of Windows 7: Same process as above installing Windows 7 and drivers. Everything seemed fine. I only turned off to plug in ethernet cable again. Installed Windows updates. This time I updated EVERYTHING. Last time, I did not do all the updates. I installed all my programs again. By this point, I'm thinking everything's fine. So I shut it down. Later I turn it back on. For about 5 minutes it runs perfectly fine. Then everything loads slowly again. I almost threw my keyboard at the computer in frustration!
So here's the TLDR version: Computer works fine for about 5 minutes. After that, programs start running so slowly that they practically lock up. They eventually load, but as soon as I try to do something again, they start running slow again and lock up again. The process repeats. The ONLY exception to this seems to be before I plugged in the ethernet cable and installed Windows updates. I am able to turn off the computer, and everything works just fine. It's only after I've updated and installed everything that this seems to happen.
Anyone have any clue what's going on? Typing this made me think of a few things to try, but any other suggestions would help.
Well...just today I was going to try something else before posting this. I was going to reinstall Windows 7 again, but the USB stick did not boot up right. It is suppose to flash up with a screen with 2 options saying Windows 7 installation and windows recovery 64bit or something like that. That did not happen. Instead, it said Starting Windows with no Windows logo for a few seconds. Then went to the "Loading Windows files" screen. Then it flashed to what looked like the Vista Starting Windows screen. After that, it just turned completely black and stayed black. So I turned off the computer and removed the USB stick and decided to try and mess with my current installation of Windows 7...except it did the same thing the USB stick did with the whole Starting Windows, to loading files, to starting windows, to black screen.
So now I'm super royally confused on what happened (did the USB stick overwrite my installation of Windows to that weird Starting Windows, to loading files, to starting windows, to black screen thing?).
So I don't even want to touch it anymore and just want to wait for help. Also let me know if you need more information.
