Problem in installation of ubuntu
AM not able to install ubuntu 12.04 OS in my PC is windows 7 doesn't support
3 answers Last reply
More about problem installation ubuntu
  1. Ubuntu will install on any Windows PC and can co-exist with any Windows version if you do it properly, but you have to create a separate partition for it. You can't install it on the same partition as Windows.
    If you want to keep Windows 7 you can install Ubuntu in a dual-boot configuration so that every time you boot your PC you'll see a dual-boot menu to choose which OS you want to use.
    How to install Ubuntu as a dual-boot setup with Windows 7:
    http://www.dedoimedo.com/computers/dual-boot-windows-7-ubuntu.html
  2. You should just be able to install it alongside windows and I think ubuntu creates this partition during installation.
  3. Make sure you are booting from CD.
Windows 7 Support Ubuntu
