Tom's Hardware > Forum > Games General > Games General Discussions > [Bug?] Mimic Generated inside a door
Forum Games General : Games General Discussions - [Bug?] Mimic Generated inside a door
Archived from groups: rec.games.roguelike.nethack (More info?)
On the final level of Sokoban I found a mimic pretending to be a boulder
on the same square as a closed door. Is this a bug? Have other people
seen this behavior?
John
Sponsored Links
"John Gibson" <johnSPAM@NOGOODlosgibsons.us> wrote in message
news:Af-dncMP0KH9Z__fRVn-iA@rcn.net...
> seen this behavior?
I don't think it's a bug... I've seen this several times.
Danny
Reply to Anonymous
John Gibson <johnSPAM@NOGOODlosgibsons.us> wrote in news:Af-dncMP0KH9Z__fRVn-
iA@rcn.net:
> seen this behavior?
> John
In a game I played about three days ago, I ran into two different occurances
of monsters on the same square as a closed door. I used 3.3.1 (haven't had
the time to go through the install.unix/install.linux of 3.4.2 yet). I'm
pretty sure one of them was a shrieker but I just can't remember what the
other was although I'm almost positive it wasn't humanoid or animal.
Reply to Chuck
> Danny
Why is that not a bug? I sure would call it a bug for a monster
to appear inside a door...
Reply to Chuck
John Gibson <johnSPAM@NOGOODlosgibsons.us> writes:
> seen this behavior?
It's not a bug. Mimics are amorphous, so surrounding a door wouldn't be
a problem for it.
: Dylan O'Donnell http://www.spod-central.org/~psmith/ :
: "Peek-a-boo, I can't see you, everything must be grand; :
: Boo-ka-pee, you can't see me, as long as I've got me head in t'sand..." :
: -- Michael Flanders, "The Ostrich" :
Reply to Anonymous
In article <Xns963BE5CD6873Fchuckonilcar@207.35.177.135>,
>> Danny
What part of it do you consider a bug? Is it that a door symbol
appeared where there could be no door? That might be a bug, but,
if there's reasonably a door on the map, and the mimic appears at
the doorway and mimics a door, what's the problem?
Even a pacifist can get around him. Engrave Elbereth, wake it up,
and it will flee.
Reply to James
james wrote:
<snip>
>>>Danny
The mimic appeared as a boulder in the doorway when the map already
indicated that it was a door (because it was Sokoban). It was a dead
giveaway of the mimic. In addition (probably because I was playing
noeGNUd) both the boulder and the doorway remained visible. However on
the minimap (which is in the normal ASCII) the square appeared as a
boulder. If mimics would pretend to be doors when they are on top of one
then I wouldn't consider it a bug.
John
Reply to Anonymous
In article <FuWdnauegqCg8_nfRVn-iA@rcn.net>,
They do, in the dungeon. Guess they are biased toward mimicing boulders
in soko.
Reply to James
> a problem for it.
How do you image a boulder surrounding a door? seems to me to be quite a
topological problem...
Reply to Chuck
The point has been explained clearly enough by others I guess, but just to
make it absolutely clear: Imagine you are say a Trifid (only non-nethack
animate plant I could think of) and part of you is on the outside of your
houses front door part outside in front of the door and the two or so inches
remaining is inside the door itself occupying the wood thereby changing its
density to woods plus that of a plant. Isn't that a undesired result which
should be handled as an exception to wanted behavoir by a game? Or at the
very least handled so that it makes sense in some (admittedly wierd) way in
the game? THAT is a bug. Didn't mean to harp on it too much, but there are
people that don't understand the intracies of what pogramming (of any sort)
can entail and this is such a case.
Reply to Chuck
>>a problem for it.
quite >a
How about if it stretches itself around the door:
___
|||,the middle one being the door.
Reply to Anonymous
> ___
IF you're not being facicious, you are overthinking it, games are supposed to
have SOME semblance to reality, and that definately is over the line...
Reply to Chuck
>>___
Exactly, I've never seen a mimic stretch itself around a door in real
life either, so it shouldn't happen in Nethack.
Chris "Bob" Odorjan - bobnet@canada.com
BobNET - http://www.execulink.com/~bobnet/
Reply to Anonymous
especially a closed door- one generally imagines a closed door with a
very small space around it, then the doorframe, which connects with the
wall; this then would appear to be half a boulder protruding and flush
with a wall.
Reply to Anonymous
more like
________
/m | m\
| m | m |
| m | m |
\__|__/____
the middle part being a door. However, this would NOT appear to be a
boulder in an Open doorway; if the boulder were smaller than the
dimensions of the opening, it would reveal a bisection by a closed
door;
if the boulder were larger than the dimensions of the opening, it would
reveal bisection by an intact wall.
It would be more adventitious to the mimic if it were mimicking the
surface of an existing closed door, or a closed door in an open
archway.
or if the mimic were at least mimicking a boulder in an open doorway,
or if the mimic were mimicking a boulder in a collapsed section of
wall,
Do mimics engulf?-
On that vein, why not have them mimick open spaces; e.g. the mimic
conforms itself to the surface of the open arch/doorway, or the surface
of a narrow corridor space
(either one is a space between two other walls)
then strikes (already has grapple attack) as you attempt to walk
through
or the mimic could fall/enter a pit and mimic normal floor, until you
attempt to walk over it.
Reply to Anonymous
chuck scrawled:
>>___
It's not much of a stretch, actually, given that there are
critters in the game that are explicitly capable of doing it. Closed
doors in nethack are not hermetically sealed, and amorphous critters -
which includes, but is not limited to, mimics - can pass through them.
This is not a bug, but deliberate behaviour, as evidenced by the message
produced when you see it happen. e.g., "The acid blob oozes under the
door."
I know from observation that acid blobs, puddings and green
slime, fungi, fog clouds, and lights are capable of this. I suspect it's
all b, P, F, j, v, y, and m, and possibly some others I've forgotten.
And that's discounting xorns, earth elementals, ghosts, and shades,
which can pass through closed doors by other means.
John Campbell
jcampbel@lynn.ci-n.com
Reply to Anonymous
"jasonnorthrup@yahoo.com" <jasonnorthrup@yahoo.com> writes:
> with a wall.
I've always imagined NetHack mimicry to involve a certain amount of
illusion-projection, rather than necessarily actual shapeshifting:
otherwise it'd be tricky for, say, a giant mimic to pretend to be a
tiny key, or a small mimic to be a boulder (which blocks LOS when
undetected, but can be seen past when you find out what it is). So, we
have a mimic plastering itself over the doorpanels that just makes
itself _look_ like a boulder sitting in a doorway.
Reply to Anonymous
> door."
yes, but I've yet to see a boulder slither under a door...
Reply to Chuck
chuck scrawled:
Which part of "MIMICS CAN CHANGE SHAPE" are you not
understanding?
John Campbell
Reply to Anonymous
chuck wrote:
> On the off topic matter, I KNOW I have a "spoiler"
> (quotes because I catagorize most of them them silimiar to D&D's
> player's guide) about exercising intelligence,
If you indeed do have such a spoiler, it's wrong.
> but all I can find is Boudjin's (sp? sorry if so) old one saying
> that you can't.
Which is, of course, correct. :-)
It's "Boudewijn", by the way. See my home page,
http://members.home.nl/bwaijers/index.html
for an explanation, or
http://members.home.nl/bwaijers/boudewijn_waijers.wav
for the pronunciation.
> If you could name me a file name I would be much obliged.
No need to. The spoiler you have by me is correct. Intelligence cannot
be exercised.
Boudewijn Waijers (kroisos at home.nl).
The garden of happiness is surrounded by a wall so low only children
can look over it. - "the Orphanage of Hits", former Dutch radio show.
Reply to Anonymous
John Campbell <jcampbel@lynn.ci-n.com> wrote in
news:Xplae.450$Nc.328@trnddc08:
> understanding?
None, but when it goes under a door does it then change to a acid blob and
then back to a boulder? VERY unlikely for random events...
Reply to Chuck
with a
the
flush
> > with a wall.
we
Or perhaps, that it still looks like a mimic and nothing like a
boulder, but it makes you delude yourself into thinking that it looks
like a boulder! And into thinking that such a thing could possibly
happen.
A.
Reply to Antoine
John Gibson <johnSPAM@NOGOODlosgibsons.us> wrote in news:FuWdnauegqCg8_nfRVn-
iA@rcn.net:
or if the door was open I guess...
Reply to Chuck
I actually did find the file I mentioned which was Nethack Instadeath Spoiler
by Trevor Powell which it says you can't exercise, gives a couple ways to
raise it (which is probably what I remembered and the says
SPOILER BELOW BEWARE!!! SPOILER BELOW BEWARE!!! SPOILER BELOW BEWARE!!!
applying a unicorn horn repeatedly will increase intelligence. Since it is
something done more than once I would classify that as "exercise" despite the
non-standard method (i.e. not reading scrolls, spellbooks etc.)
Reply to Chuck
[ spoiler ]
Applying a unicorn horn will just _restore_ lost intelligence (eg. due to
mind flayer attacks); otherwise it will not increase your intelligence.
You may occasionally increase your intelligence by eating mind flayer meat
or drinking potions of gain ability.
The code has two comments about increasing intelligence (and charisma):
attrib.c (270):
if (i == A_INT || i == A_CHA) return; /* can't exercise these */
attrib.c (394):
if(i == A_INT || i == A_CHA) continue;/* can't exercise these */
Janis
Reply to Anonymous
Janis Papanagnou <Janis_Papanagnou@hotmail.com> writes:
Also blessed potions of enlightenment.
(Magic fountains can have a gain ability effect as well, but they're
harder to spot. Thrones are a chancier business, but you may get
lucky.)
> attrib.c (270):
> attrib.c (394):
And indeed, nor does any place try to; these lines are just backstops.
Reply to Anonymous
psmith@spod-central.org wrote:
[gaining intelligence]
>lucky.)
Disappointingly, eating a helm of brilliance while metallivorous does
not increase intelligence.
Martin Read - my opinions are my own. share them if you wish.
My roguelike games page (including my BSD-licenced roguelike) can be found at:
http://www.chiark.greenend.org.uk/ [...] likes.html
Everyone expected the Bavarian Inquisition.
Reply to Anonymous
Martin Read <mpread@chiark.greenend.org.uk> writes:
> >lucky.)
It wouldn't persist when you polyed back anyway, so it's not that much
of a loss.
Reply to Anonymous
Dylan O'Donnell wrote on 25 Apr 2005 11:17:57 +0100:
> of a loss.
I thought the mental stats were unchanged by polymorphing.
"Sometimes I stand by the door and look into the darkness. Then I
am reminded how dearly I cherish my boredom, and what a precious
commodity is so much misery." -- Jack Vance
Reply to Anonymous
Rast <rast2@hotmail.com> writes:
> > of a loss.
No, all six attributes are saved when you polymorph, and reset to
those values when you polymorph again; see the u.macurr stuff in
polymon() and polyman().
Reply to Anonymous
Dylan O'Donnell wrote on 26 Apr 2005 00:39:35 +0100:
> > > of a loss.
Thanks.
Odd. In most games, including TGTNIN, mental stats are not changed by
polymorphing.
Reply to Anonymous
psmithnews@spod-central.org (Dylan O'Donnell) wrote in
news:8664yb9q7z.fsf@strackenz.spod-central.org:
> lucky.)
PLEASE read the spoiler mentioned as what you are saying is mentioned in
there as well...
Reply to Chuck
Janis Papanagnou <Janis_Papanagnou@hotmail.com> wrote in
news:d4hl1v$svf$1@online.de:
> [ spoiler ]
Spoiler
the
there as well...
lisp LIVES!!!
Reply to Chuck
> the
> there as well...
I'm uncertain what you intend to tell us here. I read your statement
>>>"applying a unicorn horn repeatedly will increase intelligence."
as if you mean to say you can exercise 'Int', which is not the case,
whether it is written in any spoiler or not. (Personally I don't read
spoiler, whether wrong or accurate, since I have the code available.)
I assume that the mentioned spoiler also contains correct information.
But I was responding to a - quoted or not - wrong statement.
Janis
Reply to Anonymous
>> there as well...
Then I'll have no alternative than to ignore your response (not personal,
just makes your response an uninformed one)
Reply to Chuck
Yes, it is annoying when you get what seems like reliable information
from the source code, only to discover that particular function has been
overridden by a spoiler file ...
Atillo, died while helpless from laughter
Reply to Anonymous
>polymorphing.
Er. In at least some editions of the canonical GTNIN, some forms of
polymorph have a chance of affecting the mind, and if they do, the
transformation becomes permanent.
Reply to Anonymous
>>>there as well...
(You would have alternatives, if you were aware of these.)
There are inaccurate and even wrong spoilers out there; apparently you
haven't heard about it. And you also lack to verify information by the
code.
There ARE accurate and up-to-date spoilers out there, but you ought to
know which ones are reliable and which are not.
You may keep on ignoring expertise and go on believe what *anyone* has
written.
But don't post mis-information, chuck!
Janis
Reply to Anonymous
> code.
> written.
none of the above, I merely asked for the opinion of someone who has/had read
such spoiler period. I believe I have implied this in my previous messages...
Reply to Chuck
look jerk, is spite of the fact that I wasn't addressing you I will answer
your message honestly: party b (janis) had not read the spoiler, therefore
didn't know what it said AT ALL, therefore couldn't comment on it in any way.
Reply to Chuck
Plonk.
-Heikki
Reply to Anonymous
a closed doorway, no less
Reply to Anonymous
>>code.
>>written.
You're being a bit blind here, chuck. The insta-death spoiler you're
reading phrases the section on intelligence rather poorly. You cannot
*exercise* intelligence by repeated application of a unicorn horn;
rather, you can *regain intelligence lost due to mindflayer attacks* by
doing same. It's easy to see how the source document can be read to
construe a different result, but that does not mean that interpretation
is what will actually happen in the game.
-Ken
Reply to Anonymous
[ Learn to quote. Use attributions. ]
Get some clue, will you? This is a newsgroup, not an email conversation.
_Everybody_ addresses everybody else.
>I will answer
Nevertheless, he was correct, and you were wrong. Now isn't that just
_awful_?
Richard
Reply to Anonymous
No, you are the only person here besides myself that even IMPLIES that they
have read the spoiler.
fair enough I will take that as fact. You HAVE read that spoiler right?
Reply to Chuck
It's really beside the point whether someone has read the spoiler, if
they are indeed knowledgeable about how the game actually works.
Spoilers are not the source code for the game, so someone whose answer
to your question is based on knowledge of the actual source code for the
game should be considered more authoritative on the subject! But read on
below...
Yes, I have read the spoiler, and I think it gives correct information
when read in proper context. Unfortunately, it's easy to get the
context wrong when reading the line about unicorn horns.
-Ken
Reply to Anonymous
>>I will answer
> _awful_?
No, Richard, you just don't get it. Chuck is *never wrong.* It is
impossible. It can't happen. You have to say it like a mantra:
Chuck is never wrong.
Keep saying it until you believe it. You have to BELIEVE!
Kevin Wayne
"For the judges of the lowest grade, to whom my acquaintences belong,
haven't the power to grant a final aquittal, that power is reserved for
the highest court of all, which is quite inaccessable to you, to me, and
to all of us. What the prospects are up there we do not know and, I may
say in passing, do not even want to know." --Franz Kafka, *The Trial*
Reply to Anonymous
Ken Cuvelier <kvcflameNO@SPAMyahoo.com> wrote in
news:1173ddc3f0d3u45@corp.supernews.com:
> below...
my point was really two fold 1) if there is a bug in the code that allows a
method of increasing intelligence and 2) if that spoiler had found such bug.
Nobody but me seemed to see that possibilty though...
Reply to Chuck
>>below...
Using your logic, quaffing potions of restore ability should cause
intelligence to go up. It is clear to me that the author of the
instadeath spoiler felt that anyone reading that section would
understand from reading it that there is hope for regaining lost
intelligence due to mindflayer attacks, but no hope for exercising
intelligence when intelligence has not been lost.
-Ken
Reply to Anonymous
if
answer
for the
read on
> > below...
allows a
such bug.
And yet, when certain people, who KNOW how the game works (from having
played it and/or the source code), told you that there was not such a
bug, you discounted them (in a somewhat antagonistic fashion) merely
because they admitted to not having read the particular spoiler in
question.
Interesting way of going about seeking information, there.
Reply to Anonymous
Previous
1 2
There are 753 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
