problem using two-weapon combat
Archived from groups: rec.games.roguelike.nethack (More info?)
I can't figure out how to put the 2nd weapon in my off hand. I do
#twoweapon and it enables/disables it. I try just wielding, which
switches between weapons in my main hand. I've tried the x and it
switches the weapons only. I've read through the guide and command lists
a bunch of times. What am I missing?
And yes, I am playing a class with two-weapon style. It occured the
first time I played a samurai that a nymph stole both my weapons, and I
couldn't get them both wielded again. I've been avoiding two-weapon
classes like the plague since, and would like to have them as an option
again.
6 answers Last reply
More about problem weapon combat
  1. Archived from groups: rec.games.roguelike.nethack (More info?)
    "mserley" <michaelserley@hotmail.com> wrote in message
    news:1186a5997t2gd77@corp.supernews.com...
    >#twoweapon and it enables/disables it. I try just wielding, which switches
    >between weapons in my main hand. I've tried the x and it switches the
    >weapons only. I've read through the guide and command lists a bunch of
    > And yes, I am playing a class with two-weapon style. It occured the first
    > time I played a samurai that a nymph stole both my weapons, and I couldn't
    > get them both wielded again. I've been avoiding two-weapon classes like
    > the plague since, and would like to have them as an option again.
    w a-a +o katana
    x
    w b-the +o Excalibur
    #twoweapon
    Danny
  2. Archived from groups: rec.games.roguelike.nethack (More info?)
    > w a-a +o katana
    > x
    > #twoweapon
    > Danny
    Thank you, that helps a lot. The question that answer led to:
    does it matter which weapon is in hand and which is in other hand?
    After having done it a couple times, I'm guessing the way to ensure
    the one you want is in hand is for it to be the last wielded..
    Wield wakizashi
    xchange
    wield katana
    #twoweapon
    That puts katana in hand and wakizashi other hand every time?
  3. Archived from groups: rec.games.roguelike.nethack (More info?)
    mserley wrote:
    <snip>
    Also remember that your main weapon hits first. In a rare case (Say,
    your main weapon is a lance) if your main weapon knock the monster back
    or destroyed, then your secondary weapon does not hit at all. Also,
    your main weapon goes through the 'to-hit' check, but your secondary
    weapon does not. So it's important for your main weapon to have good
    chance of hitting, but not so for your secondary weapon.
    In general, you should have your 'better' weapon in the main hand, and
    off hand weapon should be the lesser one.
    > Wield wakizashi
    > xchange
    > wield katana
    > #twoweapon
    I think so. If you are unsure, right before you #twoweapon, you should
    check your i)nventory and see which one is your main weapon and which
    one is the backup, and if they are not in the right order, x)change to
    swap them around.
    -K
  4. Archived from groups: rec.games.roguelike.nethack (More info?)
    > > w a-a +o katana
    > > x
    > > #twoweapon
    > > Danny
    Yes. Among other, artifact weapon cannot (in nethack) be wielded as second
    weapon and won't provide their benefits (eg resistance for the brands)
    when wielded as second weapon in slash'em.
    > Wield wakizashi
    > xchange
    > wield katana
    > #twoweapon
    Yes. The first hand weapon is the one you're wielding when you start
    #twoweaponning. The second-hand weapon is the one that was in the
    'alternate weapon; not wielded' slot before #twoweaponning.
    Hypocoristiquement,
    Jym.
  5. Archived from groups: rec.games.roguelike.nethack (More info?)
    Also, weap-343.txt has the details, but basically, your chance to hit is
    based on the worse of your primary weapon skill and your twoweapon
    skill, with an additional penalty if twoweaponing (or riding) while
    poorly skilled (in twoweaponing or riding).
    Most players advocate getting practicing your primary weapon until you
    get skilled in it, and only then switching to twoweaponing. While
    twoweaponing, you exercise your twoweaponing skill, but not your skill
    in an individual weapon.
    Kevin Wayne
    "Art is a tremendous means by which painfully guarded individuals bare
    their souls." --Steve Hindalong
  6. Archived from groups: rec.games.roguelike.nethack (More info?)
    Kremti wrote:
    > Also, your main weapon goes through the 'to-hit' check, but your
    > secondary weapon does not. So it's important for your main weapon to
    > have good chance of hitting, but not so for your secondary weapon.
    Which means, in effect, that when your first weapon hits, your second
    hits automatically as well, and if your first weapon misses, the second
    does so also.
    Note that you can only practice with your weapons whilst wielding only
    one weapon, and your chance to hit is determined by the lowest of your
    two weapon skill and the skill you have in your first weapon.
    As for the interface for twoweaponing, note that when you have the
    "pushweapon" option selected, wielding a weapon automatically pushes
    your current weapon into the secondary slot. So:
    wa
    wb
    #twoweapon
    would first wield weapon a in your primary slot, then wield b in your
    primary slot and move a to your secondary slot, and finally start your
    twoweaponing.
    Boudewijn Waijers (kroisos at home.nl).
    The garden of happiness is surrounded by a wall so low only children
    can look over it. - "the Orphanage of Hits", former Dutch radio show.
Video Games
