G
Guest
Guest
I just put together a new rig and it won't post. when i turn the power on the speaker beeps at me and continues until i shut off. also i can power on from the front button but can only power off from the switch on the back of the power supply. Does it matter which way i put the 'power sw', hd led etc. connectors into the pins. for example it says pin 11 Anode pin 12 Cathode. which is which. there is a little arrow on one side of the connector. is this the Anode side?
System components:
ATX Case & PS
iwill kk266
duron 750
geforce2 mx (leadtek)
adaptec 2940 scsi
yamaha 16 10 40 cdrw
40gb ibm gxb (p?)
please help.
System components:
ATX Case & PS
iwill kk266
duron 750
adaptec 2940 scsi
40gb ibm gxb (p?)
please help.
