Solved
Would buying a 2560x1440 monitor stretch the quality?
  • Flat Panel Monitors
  • Movies
  • Resolution
  • Monitors
  • Peripherals
Last response: in Computer Peripherals
December 28, 2012 5:23:30 AM
So I've recently heard about these ultra cheap monitors (around $300-$400 depending who the seller is) from South Korea and a lot of reviews I have read have been highly positive of their performance. If I would go for something like this, seeing as how the resolution is huge, would this completely destroy the quality of my movies? I'm highly into cinema and I do enjoy having high qualities to view. I worry though that with the resolution of a monitor such as this, it would stretch the picture (since movies only go up to 1080p but I only have 720p quality movies). So would this completely ruin the picture and make it pixelated and blocky, or is there some sort of magic that will preserve the quality with such a large resolution? Should I go for a 1280 x 720 if I don't want to lose any quality? Could I get away with a 1920 x 1080, or would that stretch the picture as well? My monitor right now is from when I first got into computing (about 5 years ago) and is only 19 inches (not exactly the greatest, nor immersive for games and movies due to how small it is). I've been eager for some time to get a larger monitor but the problem was always their expensive prices. I've always heard that once you get a high res monitor you'll never look back.
More about : buying 2560x1440 monitor stretch quality
December 30, 2012 2:16:12 PM
First thing you need to do is check what resolutions are available on your existing graphics adapter. If it cannot manage 2560 x 1440 you will have to replace it with one that can or choose a more suitable monitor whose native resolution your existing graphics adapter supports.
To often does that get overlooked by people who upgrade to a super-size monitor, only to discover that their existing graphics adapter can't put out the required resolution for it.
m
l
December 30, 2012 3:05:04 PM
I'm all set on that front, my man. Checked to make sure my graphics card could handle a super sized monitor before I even built the computer (even if there seemed to be a 0.01% chance of it happening. Wanted to be future proof for a while, plus I knew I was going to get a new monitor eventually).
m
l
January 2, 2013 11:32:41 AM
Dave,
If you are mostly watching 720p movies then you will have no problems with a 1440p monitor. Have you seen the 1440p monitors advertised as 4 x HD? Well HD = 1280x720.
This means that every pixel from your 720p video will be stretched to 4 pixels on any given 1440p display. There will be no distortion of the image because no advanced scaling algorithm is needed.
On the other hand, if you are watching 1080p video on a 1440p monitor then scaling (either by monitor or GPU) is necessary so in theory the media will not look as sharp compared to a monitor with 1080p native resolution.
I had these same concerns when selecting my (S27A850D) 1440p monitor last year but I have discovered that even with blu ray (1080p) on this display, the stretching is really not very noticeable.
If you are coming from a TN to an IPS (or PLS) display then the improved colour depth will far outweigh any 'stretching' of the picture.
I wouldn't worry about it.
m
l
January 2, 2013 11:59:18 AM
Having said all this, it should be clear that upgrading to any screen of a larger size will of course make the pixels from your 720p video larger.
No real way to avoid this unless you have software that supports proper upscaling, such as Total Media Theatre 5. This I use for my DVD's on my 1440p screen.
It seems to improve the sharpness of the image somewhat but don't expect magic.
Hope this helps.
m
l
a b C Monitor
January 4, 2013 7:15:24 PM
I went from a 27" 1080p to a 30" 2560x1600 and I will not go back. Gaming and movies are out of this world on this thing and ifit wasn't so expensive I would get two more for a three screen set up.
The bad thing is IO got this before the 2560x1440 monitors came out bec ause I could have gotten two for what I paid for this one.
Make sure you get aq high quality DVI cable (dual link). If your video card has 2 gb or more then you'll have no issues with a 2560x1440 monitor.
m
l
Best solution
September 11, 2013 12:55:48 PM
It is true that a 2560x1440 monitor is equivalent to 4 screens worth of 720p content. However it doesn't actually mean if you watch 720p movies/video that your video will take up 4 pixels worth of monitor space. I'll clarify.
When you watch 720p video and the monitor is in 720p mode (meaning you are running it in 1280x720 resolution), then, yes, correct, the actual pixels of each pixel in the 720p content will be equivalent to 4 'physical', native, pixels on the 1440p screen. It means that 1 pixel of 720p content in the source material is equal, physically, on-screen, to 2x2 native pixels worth of screen space on the 1440p screen. BUT keep in mind that is just how it converts if we are trying to think of it in relation to physical screen space. The pixel, even on the 2560x1440p monitor, is still just ONE pixel when we are running the monitor in 1280x720 resolution and watching a 720p source material. It's not treated as 4 pixels (2x2). And it doesn't require any scaling or stretching algorithm. The hardware takes care of doing that translation when you put the monitor into 1280x720 resolution but the aspect ratio is identical so there is no distortion or stretch at all. It's still truly just ONE pixel because your monitor is now in 1280x720 resolution. And it just means that the underlying hardware is converting 1 pixel of 720p source material to show up as 2x2 native 2560x1440 pixels. It will not distort the image at all. The aspect ratio is exactly the same (1.777...78). It's a perfect match.
There is no "upscaling" or "downscaling" happening. Upscaling and downscaling happen when you have source content that is higher or lower resolution than your monitor is capable of or if the aspect ratios are different. There are many scenarios. But the main thing here is nothing is being "upscaled" or "downscaled" if you view 720 on a 1440 (as long as your 1440 monitor is in 1280x720 resolution or capable of it).
Scaling of any type only occurs when you start getting into different aspect ratios or when you have source content that needs to be shown in a different target resolution. For example you have some older 480p source content but you want to view it on a newer 16:9 aspect ratio TV that's lowest resolution is 720p (just hypothetically). In this case there is going to be some scaling of the content. Also, yes, if you want that source image to "fill" the screen it will need to "stretch" some of the picture because 480p source material is a different aspect ratio (typically 3:2 versus the usual 16:9 or 16:10 we see today). Another example of scaling would be watching a YouTube video but you have your monitor set to native 2560x1440. The video plays in say 720p. But because your monitor is in a higher resolution than the content it is upscaled while it plays inside the player. I would still dare anyone to try to find differences between the upscaled version of 720p playing in an embedded YouTube video versus playing that same 720p video after switching your monitor down to 1280x720 versus watching that same video on a native 720p display (of exactly the same size, viewed from the same distance). The differences are truly minuscule.
If you have the same aspect ratios, same resolutions, or equipment capable of switching to that resolution, then no scaling or stretching of any significance will occur.
Anyone who thinks there is something wrong with watching 720p on a 1440p monitor and somehow the quality "changes" (it doesn't) doesn't know anything about aspect ratios and is also sitting too close to a monitor that was designed to be viewed with material at 4 times that resolution. Of course if you watch certain material in 1280x720 resolution on a 27" screen from 10" away at your computer desk you are going to see some grains (versus say watching Monday Night football in 720p on a 40" from 10ft away). But I can assure you there is no difference whatsoever, no distortion, scaling, stretching, etc... of any kind taking place. It's just simply that 1280x720 from that distance doesn't look so great when you compare it to full native resolution of 2560x1440 (obviously - that's 4 times the pixel density).
May 23, 2014 3:32:31 AM
that's a good explanation ..
m
l
