What should be the distance of cad5 cable for proper speed
Last response: in Windows 7
Related ressources
If you're going through the trouble of burying a cable, definitely make sure you run the best cable you can afford. A conduit is a must, also. This way you can always pull at least one more if need be. And don't run stranded cable either. And no 90 degree bends!
here's cable - http://www.cablewholesale.com/specs/cat-5e-outdoor-cabl...
Here's best cable - http://www.cablewholesale.com/specs/cat-5e-outdoor/10x6...
if you live on the water table, here's cable - http://www.cablewholesale.com/specs/cat-5e-outdoor/10x6...
