Alright, Sir ... here's my response.
First, I don't want an argument, either. But it looked like you were starting one to me. That's what happens when thoughts don't translate well on the screen.
Secondly, it's obvious that I put you on the defensive. My profound apologies. I should know better.
With that said, I would like to make a couple of comments. Nothing is intended but to offer educational information. If you wish to disagree with me, go ahead ... you won't get flamed again by me for having an opinion. But I'd like you to listen to what I have to say, first ... if you don't mind.
I build and repair systems for a living. I've seen <i>a lot</i> of PSU's. Antec PSU's have the highest failure rate of any that I've installed in my shop. I mentioned the 400watt, specifically, because these are the ones that fail most often. I've come to believe that the efficiency level pasted on the side must be a misprint.
I'm aware that Antec PSU's are on the AMD-recommended list. But I think that list is just a general rule-of thumb, and I have found that the real-world requirements of newer systems <i>often</i> exceeds the recommended specifications. Try to look at it this way. If you buy a software program, and the minimum requirements are a 300Mhz processor, and 32MB of RAM ... and this happens to be the exact specifications of your system, then the program might run ... but usually not very well. And sometimes, not at all.
That's exactly how I view the AMD-recommended list. Most of the PSU's listed are the bare minimum. They will work, most of the time, but not necessarily at an optimal level. I really don't think that anything was taken in account beyond getting the computer booted up with a minimum of peripherals, such as one hard drive, a single stick of memory, a low-end video card, and the processor. Heck, when the list came out ... GeForce256 cards were just beginning to hit the market. In fact, unless my memory is incorrect, I believe the list might have preceded that video card. (And the GF256 needed a lot of juice.)
Yes ... I've noticed in the past that Enermax PSU's are not on the list. Why? Good question. They are considered by some to be the best on the market. Neither are Leadman PSU's, which are generally excellent in quality, and competitive in price.
All this really tells me is that the list is sadly incomplete. And so, I rely on my own judgement ... which I consider to be a better use of my experience than trusting an outdated web page.
You mentioned that you <i>had</i> taken the time to add up the power requirements for your system. Pardon me, (and again, I don't mean to get into an argument) ... but it is kinda obvious that you have not done this. Or that you don't really understand how a PSU is designed, or how the PSU delivers current to the different peripherals. Or that your math is wrong.
Part of the reason I am sure of this is because you also mentioned running your PSU at full load, and said that it happened several times.
Um ... that's not good. Your PSU should <i>not</i> be running at full load, and definitely not on a regular basis.
In case there was some confusion by what I meant ... I didn't mean running your <i>system</i> at full load. I was talking about the PSU. Just the PSU. And any PSU that regularly hits a full load will eventually crap out on you. Unfortunately, some PSU's that fail have a tendency to send a high level of current through the system at the moment of "death" ... and that can do some damage; especially to a video card, the memory, a hard drive, and a SCSI controller. And the Antec PSU's are bad for doing just that.
I won't get into it any more than that ... but I highly suggest that you do some research on the subject and become better informed. I'm not saying this to be insulting. That is not my intent. I'm saying it because I think it would be a good idea.
To get you started, here is a link that will help:
<A HREF="http://www.gamepc.com/reviews/hardware_review.asp?review=psroundup&page=1&mscssid=&tp=" target="_new">http://www.gamepc.com/reviews/hardware_review.asp?review=psroundup&page=1&mscssid=&tp=</A>
Feel free to respond again, and good luck with your computer.
Toejam31
<font color=purple>My Rig:</font color=purple> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
