Tom's Hardware > Forum > Systems > Dell > Dell Monitor Wall Mount
Forum Systems : Dell - Dell Monitor Wall Mount
Archived from groups: alt.sys.pc-clone.dell (More info?)
Is it possible to remove the base from my Dell 17" LCD flat panel
monitor, Model No. E172FPB, and mount the monitor itself on the wall
in front of my digital piano? Does anyone know of any hardware bracket
or mount that will work with this monitor? Any help will be
appreciated. Thanks.
Sponsored Links
Remove the base from the LCD, Then get some HEAVY DUTY piano wire or
picture frame wire (I Used 6' of Electrical 12 guage THHN copper wire)
and attach to the back of the LCD (I fished it through the vents in
the top and sides), get a decent heavy duty picture hanger setup and
hang from that (Find a stud and screw it in. I did it with a Viewsonic
20" - I cut a hole just above the baseboard and fished the wires down
to it, got a 30 cent plastic wall plate and cut a larger hole in it
and then ran an extension cable to the cpu, the long power cable
reached. Been hanging for over a year now. I doubt you will find a
bracket that will do this and if you do it will probably cost big
$$'s. I did this for under $10
Glassman
Reply to Anonymous
I'd bet there are four screws, in a square, on the back. VESA standard
mounting screws.
Tom
"Filipo" <fooltergeist@yahoo.com> wrote in message
news:62db7324.0409020602.3b5210c8@posting.google.com...
Reply to Anonymous
And then go to www.ergotron.com, or google for "VESA mount".
NGA
"Tom Scales" <tomtoo@softhome.net> wrote in message
news:uJednSyg69acdqrcRVn-og@comcast.com...
> mounting screws.
> Tom
Reply to Anonymous
There are 1319 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
