Closed
Help me find good monitor for build?
Last response: in Computer Peripherals
Here is my build...
PCPartPicker: http://pcpartpicker.com/p/taiYCPU
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: ASRock Z77 Extreme6 ATX LGA1155 Motherboard
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1600 Memory
Storage: Crucial M4 128GB 2.5" Solid State Disk
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 670 2GB Video Card
Case: NZXT Switch 810 (White) ATX Full Tower Case
Power Supply: Corsair Professional 750W 80 ATX12V / EPS12V
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer
Operating System: Microsoft Windows 8 Professional Full (64-bit)
Using this computer for gaming, stocks, recording/editing/processing videos, watching blu-rays, creating digital paintings. Looking for a monitor that is 24". Thanks for your time!
  • Mousemonkey has closed this thread
Best solution
What is the budget amount for the monitor ?
Here are a couple to look at for under $300 and not knowing your budget figured it might be around that. If your looking for a 27" you can get one for under $300 as well. I currently have a HP monitor and it has been working fine and previously have had Samsung monitors and they also work fine.
You can't go wrong with LG , Samsung , HP and Asus for monitors.
