omaroma11 Honorable Jun 6, 2012 332 0 10,810 Jan 5, 2013 #1 would the turtel beach x12 benefit from a sound card
Solution inzone Jan 5, 2013 It will if you can plug it into the sound card. If you use it by usb then your using the onboard audio from the motherboard.
inzone Champion Mar 12, 2011 14,971 1 51,960 Jan 5, 2013 Solution #2 It will if you can plug it into the sound card. If you use it by usb then your using the onboard audio from the motherboard. Upvote 0 Downvote Solution
omaroma11 Honorable Jun 6, 2012 332 0 10,810 Jan 6, 2013 #3 Best answer selected by omaroma11. Upvote 0 Downvote
