CMOS RTC Battery Toshiba Satellite M45 M55
Last response: in Laptops & Notebooks
You can check under the panels on the bottom side of the laptop to see if you can access it that way. If not, you may have to tear the whole works down. If that is the case, have a look at the disassembly guide at the top of the forum here.
Ask the community
